VISION PTS 4241 LCD TV
HAVE JUST PICKED UP THIS SET HAS DARK DISCOLOURED SCREEN AND HAS EFFECT JUST LIKE SPILT TIN PAINT RUNNING ABOUT 1/8 OFF TOP OF DISPLAY UNIT
Vision 4241 screen gone black sound and power up perfect any ideas anybody
Posted on Dec 05, 2008
    Problem Solver:
  • 9 Answers
You have to replace the xsus board
Posted on Mar 12, 2009
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
Dark run looking spot of screen
Probably a bad backlight tube. It would look like a darkish about 1" (2.5cm) wide streak running near to horizontal part or all the way across screen.
May 03, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid 4241-TLXB wont stay on
I think I may have just solved this issue. Remove the back covers and turn the tv on until it the screen goes black. There will be a little red led that will light up when the screen goes black. right above that light there is 4 little swiches, the bottom one is labled BURN. Switch that one to the opposite direction. I don't know how but mine has been working for a couple days now with no issues. GOOD LUCK!
Jul 05, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Dark burn in? at top and bottom of screen. TV is only 16m old.
PixelProtector is a tool for fixing stuck pixels, removing screen burn, correctly calibrating screens for optimal performance and gaining the best possible picture. Any large screen television is an investment. Poor set-up and calibration can degrade the quality of a television's image and severely threaten the life of the screen.
If you own a large plasma or LCD television with a DVD player and want to achieve optimum performance, PixelProtector is highly recommended.
3 ways to remove burn-in
1. PixelProtector for Removing Screen Burn.
2. downloading a free program called JScreenFix
3.
Screen Burn Removal Using Your PC.
If you can hook your PC up to your screen burnt TV try this. Create a folder in 'My Documents' called 'Screen Burn'. I'm not joking keep reading. Now open up a picture editor like 'paint' available on all Windows PC's. When you run 'Paint' a blank white document is what you should have in front of you. That is exactly what you need. Select File – Save as and name your picture 'white'. Be sure to save it in the folder you just created.
Next you need to click on the 'black' section of the colour pallet at the bottom of the 'Paint' window. After you have selected black click on the 'Fill' icon (a tipped paint pot) on the left. Now simply click in the middle of your white picture and it should become totally black. Select File – Save as and name you picture 'black'. Again be sure to save it in the folder called 'Screen Burn'. You don't need paint any more so you can shut it down.
Now right click on the Windows desktop an select Properties – Screen Saver and using the drop down list select 'My Pictures Slide Show'. Now to configure the slide show. Click Settings and configure as follows. Slide the bar to 'More' so that pictures change frequently. Slide the next bar to 'Larger' so pictures fill the whole screen. Now click the 'browse' button and find the folder you made called 'Screen Burn'. In the next set of options:- Check 'Stretch Small Pictures', Un-check 'Show File Names', Check 'Use Screen Transitions' and finally un-check 'Allow Scrolling Through Pictures With The Keyboard'. Save the options.
Different versions of Windows might have slightly different configuration options but as long as the result is a completely filled (no borders), alternating white and black screen with no writing then it will probably help.
Now set your screen saver to 1 minute and leave the keyboard and mouse well alone.
As with the 'snow' and 'signal pattern' leave this for a while to see some results. If you use your TV for the PC then it might be a good idea to use this as your regular screen saver and run it frequently.
The only snag is the headache of connecting the PC up and the fact that removal technique will not be running at your screens native resolution.
Here are some more resources:- PixelProtector Screen Burn Removal and our old screen burn home page
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black lInes on screen
i have a white line vertical in the midle of tv
Nov 25, 2007 | Hyundai HPT-4250 Television
Samsung LCD TV shimmer problem
Are you sure this is not an LCD screen door effect, It is a normal thing for this to happen to an LCD TV set. They are not made to be watch too close or you will magnafy this normal effect with the screen. If you have a problem with a new set, dont waist any time and get it service right away as it will cost you a small fortune in the future to have it serviced. Good Luck
Mar 24, 2007 | Samsung LN-R409D 40 in. LCD Television
Dark screen at top of TV picture
If this is a projection set then a center channel speaker sitting on top would have no effect.
Feb 03, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
514 people viewed this question
Top Televison & Video Experts
Electro Med Services...
