Question about Whirlpool Duet GHW9150P Front Load Washer
Trouble code f35
I keep getting a trouble code f35 on my whilpool duet washer. My book doesn't tell me what that is. Can anyone help. I have to unplug my washer and restart and it will work fine for a few loads.
    President:
  • 1,430 Answers
The problem is likely the analog water level switch is failing. A pretty common problem in this machine. Before replace check the hose that goes to it for any blockage. If the hose is not plugged up the switch will need replaacing. Not a cheap part either but easy to replace. It is a small square block with wires and a hose going to it located under the top cover panel. For diagrams and illustrations enter your model # at www.appliancehelponline.com
Posted on Jul 13, 2010
My whirlpool duet keeps getting the f35 error code. I have checked the drain motor filter (found hair pin) & drain lines are clear. After taking it apart I can get it to work about 3 times then it...
Hi
The "F35" error code is indicating a problem with the ANALOG PRESSURE SENSOR switch operation .There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. (See image) The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting the error message F35. Can you tell me what that means?
The Central Control Unit detected a fault in the analog pressure switch but it could also indicate a draining problem. Check the link below to see what you can try to address the problem.
Troubleshooting Error Code F35 on Kenmore Elite and Whirlpool Duet Washers
Nov 03, 2010 | Washing Machines
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting a code F35 mid cycle,have to unplug washer to reset...any help?
F35ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked
Whirlpool Duet Washer Fault Codes
Dec 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer with f35 code
unplug it from the wall and let stand for 5 mins - sortof like rebooting the pc
Plug back in and reset the dial to whatever you require
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer flashes f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader
I've had this same problem and had a service man come in. The reason for the colde is an over-gunked up machine due to the directions for amount of soap to use on he bottles being incorrect.
Run the washer empty several timres with just vinegar in place of the soap and then repeat with bleach. I've been told this will take care of the problem, but it may take many cycles before the codes will stop appearing.
Also, from then on, only use 3 tablespoons, yes 3 tablespoons or 1 ounce of detergent per wash. The 1/4 cup that most he detergent bottles tell us to use is way too much.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
