Question about Refrigerators
Can I disconnect the freon from the freezer compartment and just use the fridge compartment?
    President:
  • 1,561 Answers
You cannot, because you need to know some basic things like, this is manufacturer design and an in built refrigerator with factory specification. the fridge compartment receive it coolness from the freezer freon, the freezer is the house that supply the fridge compartment cool air that makes the fridge compartment cool, so to disconnect the freezer freon from the fridge, where will the fridge compartment receive freon from?
I advice you just get only fridge compartment if that is what you need instead of damaging the one you have at the moment.
Take care.
Posted on Jul 13, 2010
  • julie
    julie Jul 13, 2010
    This is a compact fridge, haier BC-111, and the lines are separate. I thought the model was at the top when I sent the message over. It has a tiny freezer compartment that is leaking.
  • julie
    julie Jul 13, 2010
    One of the freezer lines was punctured while defrosting.
4 Suggested Answers
lojacksdad
  • 121 Answers
SOURCE: I punctured the freon line in the freezer, will the refridgerator still work.
no sorry to tell you this type of problem is not worth repairing
Posted on Apr 17, 2009
woodchuck789
  • 4070 Answers
SOURCE: the freezer compartment on my under counter fridge
I'm not sure about yours but on most the fridge compartment gets it's cold from the freezer so you can't run it separately.
Posted on Jul 15, 2010
Testimonial: "As I suspected. Great. Quick response. Thankyou."
  • 2006 Answers
SOURCE: I have a hole in
Bill, unfortunately it is not a cheap fix. At least $100 for the freezer coil; about $40-50 for the freon charge and then labor and that will run at least $100 more and probably twice that. It is NOT something that a DIYer can do, it will have to be a trained technician. Usually for the cost of a service call a technician will give you an exact estimate. But some companies will give you a ballpark estimate over the phone for no charge.
Sorry Guy! I don't like to give bad news!
Posted on Jun 22, 2011
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
Our Subzero 611 (fridge above, freezer below) is leaking water behind the unit. We pulled the unit out of the wall and discovered that the center panel on the back of the unit had a big rusted spot. We...
That is the suction line which carries refrigerant (freon) and indicates a sealed system problem which must be attended to by an EPA "Certified" Technician.
Jul 04, 2011 | Sub-Zero 611 / O Bottom Freezer...
Freezer not freezing food,and fridge not getting cold.
Hi, both compartment of the refrigerator (freezer & fridge) not freezing and getting cold means you have low or empty freon (gas) in the compressor of the refrigerator and you need to refill it as soon as possible.
Take care
Jul 14, 2010 | Frigidaire FRT17G4B Top Freezer...
Got a daewoo upright fridge freezer no frost multiflow system,light is on in fridge compartment but everything else as stopped working,everything has defrosted can you help please
Just try to check wethere the compressor is working or not. but if working. maybe theres a leaking in the the tube. causing no freon inside.you need to reprocess your freezer .
Jun 30, 2010 | Freezers
At first the freezer wasn't freezing and the fridge part was getting cold, now it's reversed, the fridge is not getting cold and the freezer does...It does runs, could it be freon?
Turn the freezing unit down to the lower number,and the fridge compartment up to about 7 or 8.Leave it over night to balance.
Mar 14, 2010 | Refrigerators
Both Freezer & Fridge compartments not cooling
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon change fan motor
Aug 12, 2009 | Refrigerators
Whirlpool Compact Refrigerator w/ top freezer not cold enough in either compartment. Model: ETOWSRXMQO
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath or you may need freon
Aug 08, 2009 | Refrigerators
Maytag fridge not cold
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Mar 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
