Question about Nintendo DS Lite Console
Ds lite HELLO AGAIN MAANITA,JUST LETTING YOU KNOW THAT I ALREADY TESTED THE TOP HALF AND THE BOTTOM SCREEN ON ANOTHER MOTHERBOARD FROM MY NEPHEWS DS AND THEY WORKED FINE,SO IT SEEMS THAT SOMETHING ON THE MOTHERBOARD IS CAUSING IT,THE GREEN LIGHT STAYS ON WHEN YOU SWITCH IT ON BUT IT SEEMS THAT NO POWER IS COMING TO THE SCREENS WHATEVER IS CAUSING THAT,HAVE YOU EVER HEARD OF THIS?
  • 119 Answers
You can check if the fuses (f1 and/or f2)are blown
Posted on Jan 06, 2009
    Genius:
  • 1,142 Answers
Hi...it is an issue with the motherboard as u told the light would stay on but no power on the csreen..the circuits on the motherboard have gone bad as the are not able to distribute power...plz get the motherboard replaced
Posted on Apr 20, 2008
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
DSLITE
can u specify the make and model
Apr 19, 2008 | Nintendo DS Lite Console
I have just changed the top screen and now when i turn it on the screen flashes and turns off
Depending on which screen flashes tells you which screen is faulty. If the screen you have just changed flashes then it is the bottom screen that is faulty. However I have known the DS to be rather sensitive when it comes to connections. Take the DS apart again and reinsert the ribbon cables that connect the screens to the motherboard. This will hopefully correct the problem.
Hope this helps.
Jul 31, 2010 | Nintendo DS Lite Console
My nephews ds lite has been water damaged for years and i don't know if i can fix it.
Well try taking it apart and letting it dry, and you can buy replacement DS parts, such as top/bottom screens, from Amazon. however, to take it apart, you're going to need a triwing screwdriver, also available on Amazon.com.
Feb 18, 2010 | Nintendo DS Lite Console
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Ds lite top screen only displaying many vertical colored lines
the only thing you can do is buy a new ds. you can try to sell that ds to another person who thinks they can fix it.
Jun 04, 2009 | Nintendo DS Console
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Top Screen on DS only shows lines
I take it the item is a ds Phat??
Problem is the same if its a Lite just a different part.
DS Phat - you need the screen cable that runs between the bottom board and the top connsctor board.
DS Lite, the screen and cable are all in one, so you need a new top screen
Nov 22, 2008 | Nintendo DS Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
139 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
