Question about Intel Motherboard
After a lightning strike my p4 computer no longer function
My tecnician told me that the motherboard is destroyed. cannot find a replacement for p4 motherboard.
  • 35 Answers
You Can Use Intel 845 Or 945 Motherboard.
Posted on Jul 13, 2010
Had Lightning strike. TV box destroyed and tv does not get power. Which boards may need to be changed?
The power supply board is the first board to feel the impact of a lightning strike.. Try that one out first.
Jun 21, 2016 | Televison & Video
Lightning strike, power was out for no longer than a second and came back on - only TV has been effected and will not respond by remote or tv button. Shows it is on. But only getting fast clicking noise...
Hi Johnson,
Only 50% chance that the symptoms was caused by a lightning strike because your cable box was powering on fine. Most of the cases when lightning strike near to your area, possible of multiple damaged to the electronic device not only to one particular appliances, most especially if they are plugged into the outlet. Also, fuse will blew because of excessive voltage.
I've suspected that the symptoms was only a co-incidence of lightning strike. If you can hear the clicking of the relay, this is only means that the standby power supply is working fine. However, this board has multiple output voltage feeding the other boards to function well. This kind of symptoms is a power supply related problem.
If you have necessary tools and test instrument and handy with electronics, you can troubleshoot this board to find the faulty parts like open fusible resistors, shorted transistors/IC's, leaky electrolytic capacitor, etc.
Another option is to replace the entire power supply board, this is more convenient if you are going to DIY because no soldering required. Try to find you board HERE. Type the model no. of your unit to the search engine, available parts/board will be display.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 31, 2011 | Vizio 42 in. LCD TV
Lightning strike near house. Power surge came through phone line and ethernet cable. lost modem, computer, time machine, house security system, and HP Officejet 6310xi. When printer is connected to power...
From your description the HP printer is damaged beyond repair, when a lightning strike occurs it also went through the power supply affecting the main board and destroying ic's and other parts. It is more than likely the interface cord from the computer to the printer also took a jolt hitting the printer from both sides finishing off any chance of recovery, you would be further ahead replacing the item.
Jul 06, 2011 | HP Office Equipment & Supplies
Our hp printer j4680c took a lightning strike. We replaced the power adapter but when we plug it into the printer the light goes out on the adapter. Is there anything else we can try? The unit doesn't...
This sounds as if it has shorted out the main power board inside the printer. Some small TV Repair shops handle out of warranty printer repairs, but will charge considerably for this. Unless your willing to pull it apart it would be more economical to replace the printer. But ask around, someone may be willing to give you a quote, and this should be weighed against the cost of a replacement
Unfortunately with lightning strikes the amount of power surging up the line can destroy many components inside the printer,and not much can be done from the outside.
Sorry it was not the answer your looking for, but lightning is a electrical devices worst enemy!!
Regards GM
Apr 12, 2011 | HP Photosmart Premium C309A All-In-One...
I had a lightening strike at my home. Since then, the garage door does not function with wall switch or remotes. when i press the switch, light comes ON on the door opener and i hear a click but nothing...
Well, I don't think that disconnecting the garage door from the garage door opener would affect function.
The lightning strike could have destroyed the circuitry inside the garage door opener, seeing that it won't operate with the wall switch or remotes.
It's likely that a board was fried by the lightning which would render the garage door inoperable.
Aug 08, 2010 | liftmaster Chamberlain Garage Door Opener...
Receiver tuner out after lightning strike
you more than likely have a F.E.T.(Field Effect Transistor) front end tuner,very susceptable to lightning or static charge damage, chech your home owners insurance, you might be able to repair or replace the tuner but it wont be cheap
Sep 26, 2009 | Onkyo HTR500 Receiver
I buy this board in 20/02/2007. If I have a
Usually the boards are covered for at least a year. You need to contact Foxconn's warranty department. They'll give you an RMA number and then you have to send the board to them which they will then replace.
Here's the website:
http://www.foxconnchannel.com/EN-US/support/RMA_Detail.aspx?ID=en-gb0000001
It says you get 3 years. Awesome!
Feb 21, 2009 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
Lightning
In a nutshell, yes and not only to a Dell but to most computer brands/models. In some instances, it's only the modem, router, LAN card that gets fried while some gets everything toasted.
Incidentally, even a near lightning strike is enough to cause big problems.
Kind regards.
Dec 12, 2007 | Dell Dimension 2400 PC Desktop
My computer is dead
This will be like a needle in a haystack. It could of fried the board, the processor, the hdd and so on, unless you are equiped with all sorts of spares, i would put the responsibility on a local repairer, but that's not to say they won't charge you for every part until the come to the faulty part themselves.
Jan 10, 2007 | Acer Aspire 3004LCi Notebook
Intel Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
