Question about Lexmark T630 Laser Printer
Lexmark E450 printer - Noise coming from the tray area when the paper tray is less than half full - noise goes away when tray is full and more paper is added.
  • LXK Chris
    LXK Chris Jul 13, 2010
    Try turning the tires inside out/ reversing the tires, it might help with the picking. Might have something to do with the pick arm assembly, the roller or the gear inside the printer.
  • grmaestas Aug 04, 2010
    The noise starts when the paper in the paper tray gets low and the noise goes away when the tray is filled.
  • 461 Answers
SOURCE: Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Posted on Dec 31, 2008
  • 44 Answers
SOURCE: The paper feed jammed allowing some print/now says empty but not
Look at the paper path very carefully. There might be a piece of paper that got torn off and is either jammed up in the fuser or the registration assembly.
Posted on Jan 06, 2009
  • 93 Answers
SOURCE: lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
Posted on May 31, 2009
  • 320 Answers
SOURCE: Clanking noise when printing from tray 1
if your getting this noise on every print job the fuser is usually the cause if they have been running on a bit hot they will get flat spots on the pressure roller and it will create a loud kind of clunking sound real common on lexmark lasers. it can also be an envelope setting on some lexmark lasers they have a solonoid for envelope feeding if the envelope inhancment is ingaged in the menu thiscan also cause such a noise
Posted on Aug 28, 2009
SOURCE: I have a Lexmark E240n
does the exit switch stick up in the back of the fuser into the paper path? I've had to replace lots of the exit sensor flags because the top half was broken off while clearing a paper jam.
Posted on Sep 18, 2011
Noise from tray and then paper stuck
A replacement is needed for the following parts:
40X2838 Media (ACM) drive assembly40X5930 Media feed ACM clutch CBM40X2853 ACM drive shaft assembly
Please contact Lexmark Technical Support for further assistance.
Feb 13, 2012 | Lexmark E250dn Laser Printer
My printer has plenty of ink but will not print properly
my lexmark is connected to my pc, my ink is more or less full it is making all the right noises for printing but the paper comes out blank...........please help its a lexmark 1200
Jan 10, 2011 | Lexmark X2670 All-In-One Printer
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
Feb 23, 2009 | Lexmark E450dn Laser Printer
Jan 06, 2009 | Lexmark E232 Laser Printer
Easyshare 500 printer
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Dec 11, 2008 | Kodak EasyShare Photo Printer 500
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark C910 Paper Jam
Could just be feed rollers are not picking paper properly. If they are dirty or dried out.....paper isn't getting to the input sensor in the correct time. Try cleaning with at least 70% Isopropyl Alcohol. Other thing to check for is...make sure there is not a tiny piece of paper stuck in paper path that is blocking the page coming out of the tray. If a previous jam was removed.....a piece may have ripped off and is hidden somewhere.
Mar 03, 2017 | Lexmark C910 Printer
Lexmark t640 noise
Lexmark says that this is a feature called Envelope Enhance. Two rollers 'thump' to remove air pockets in the envelopes to prevent creasing and wrinkling. The "feature" can be turned off in the Paper Menu.
Apr 11, 2008 | Office Equipment & Supplies
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Lexmark T630 Laser Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
