My fonts look blurry.... i tried to change the resolution but it still doesnt work. I tried the highest one and it worked but some things are still blur.. Whats the problem about? im using acer vista... Please help asap! thanks.
    Sniper:
  • 52 Answers
Hi
try this.
go to "panel control", and search for "clear type". read all the messages and see if the fonts are good after that
hope i have helped
good luck
say if solved
rate
Posted on Jul 13, 2010
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
Thefonts went smaller that i can't read it
go to display properties
then select from the tab appearance then youll find a font size there
May 18, 2011 | Computers & Internet
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
My daughter played toontown and when she quit it completely changed my screen resolution and blurred out my screen fonts. I fxed the resolution but now the fonts on my desktop are permanently blurry.
try updating your graphics card drivers, if that doesn't work, try restarting the computer, going into advanced boot options, and then, first select last known good configuration, and if it doesn't work... try using system restore... if that doesn't work as well, it means, that a startup program might be at fault, try this..
http://support.microsoft.com/kb/310353 ...
Good luck with the steps..
Nov 22, 2009 | Disney Interactive Disney's Toontown...
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Westinghouse LVM-37W3SE PC Monitor
1. Genaraly 14" and 15" Monitors supported Up to 800by600 some monitors 1024by768pixels 17"monitors supports 1024by 768 to 1280by960 pixels and Other 19",21" are supported 1280by1024 pixels at the same time change the screen Refreshrate at display properties.
Oct 01, 2008 | Computers & Internet
Last night was playing game on internet outside and my battery warning light came on and prompted me to 'HIBERNATE' . after a little while I plugged in and opened my Vistas but the icons and the font were...
have you tried to restore your laptop to an earlier date? this is called system restore.most iof the time this simple solution works....(but just to give you a heads up...items or things you might have downloaded after the date you restore you pc to might be lost...)
how to do it:
click on Start button > clicking All Programs, clicking Accessories, clicking System Tools, and then clicking System Restore.‍ If you are prompted for an administrator password or confirmation, type the password or provide confirmation
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
