I have a Sony KDF E42A10, My picture got real dark & adjusted the picture settings with alittle help but still dark. I replaced the lamp bulb but still no help.What else could it be?
    President:
  • 1,099 Answers
you can fix this by opening the back cover of the television, locate where the z sustain board is
replace the z-sus board and then check all the fuses again CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE
Hope this helpout
Posted on Jul 13, 2010
I have a sony kdf-e42a10 that will work for about 2 or 3 miutes at a time then losesound and picture for about a minute. green powerlight will flash while not working.
Hello, the lamp is going bad, use only a genuine Sony lamp in that set to keep from damaging the ballast. the part # is XL-2200U....tks
Aug 02, 2014 | Sony XL2400 LAMP - TV KDF-E42A10,...
Ony KDF- E42A10 lamp needs replaced, should I replace the fan also, just got a new lamp 8 months ago picture is dark
Usually the lamp gets brighter when it begins to fail. I would check to see how dirty the inside of the set is. There are beam splitters and lcd filters in that set and if they get dirty then you lose picture quality.
Nov 18, 2012 | Sony KDF-E42A10 42 in. LCD Television
My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
Replace lamp in tv to get problem solved.
Thanks.
Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
I have had my Sony KDF-60WF655 unit and the screen is going dark.
The screen is dull but I can see the picture , Will changing the bulb help?
Sep 06, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Replaced bulb in a kdf-e42a10 and worked for about 8 hours
3 times red light blinks shows that Lamp Cover is Open. Please put back lamp cover properly.
I would recommend to always replace with Original Sony Lamp and avoid aftermarket or compatible lamps.
Feb 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Ihave a sony KDF-E50A10 and the picture is fading
check the lamp timer in the menu page of the projector.it it is more than 1500 hours, it can be the lamp
alternativly u may also check the optical engine as it may be covered with dusty , hence resulting in dull images
Feb 06, 2009 | Sony (XL-2400) Projector Lamp for...
Sony KDF-E42A10 Screen is Not Bright
try a lamp first, through best buy their about $150 -250. If that fails it might be the optic block assembly which is about $1,000, and i just recently had replaced, and the picture is as bright and clear as when i got it two and half years ago
Sep 01, 2007 | Sony KDF-E42A10 42 in. LCD Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
