Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Why does my cuisinart stop brewing half way through it cycle? It's the 10 cup and we dont do the 1-4 cup option.
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the Cuisinart.ca website, you can select the product you are looking for and download the instruction booklet from the product page.
http://www.cuisinart.ca/en/pdf/ibs/DGB-600BCC_en.pdf
Hope that helps!
Posted on Oct 17, 2008
  • 12 Answers
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Posted on Dec 27, 2008
  • 85 Answers
SOURCE: My cuisinart coffe maker takes a half an hour to
Hello klj9,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, klj9. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
  • 464 Answers
SOURCE: My Cuisinart 10 cup Grind & Brew does not
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Posted on Nov 08, 2009
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
1,006 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
