Question about HP JBL Platinum Computer Speakers
Speakers not working
Hey, I can see this has been posted a few times, but none of the others seem to solve my problem.
We've just gotten a new Compaq computer, with Vista, and we're unable to get our speakers to work. The computer seems to claim it already has working speakers, and it detects when I plug in or out my speakers, but the Power light on the speakers won't light up. (Clearly JBL Platinum speakers)
Any ideas?
I have the same problem with pluggng speakers into dell computer. I see on the dell there is no provision to get power to the speakers as there was on the presario. There is a power (12V) wire that does not have a place to go into on the dell.
Posted on Nov 19, 2008
Hey I've had my Logitech z506 speakers for a few
I don't know for certain but, this is usually a sign of the overload circuit in operation. Speakers are not designed to be used on full volume constantly. Next time this happens try and turn them off for a couple of minutes, when you turn them on again try with the volume lower than when you turned them off. If you are regularly using them at full volume, then maybe it is time to invest in a more powerful set. Buy them by their RMS power output, NOT by their PMPO (peak mean power output) this is already an inflated figure and is usually about 4 times the real power output. I hope this helps.
Jan 21, 2013 | Audio Players & Recorders
Cyan not printing on canon mg5350 ?
Hey everyone, thanks for the helpful comments. Black and white are working for me but none of the rest are. I've replaced all the cartridges with new ones and I've tried a deep clean but nothing is working. The printer is only a few months old and I use it a few times a week but not too often. Any suggestions?
Jan 14, 2013 | Canon MG5350 Wireless PIXMA Inkjet...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
moz-screenshot.pngmoz-screenshot-1.pngYour front panel audio / microphone connector has an AC97 connector inside which looks like this:
http://www.digitaldingus.com/reviews/silverstone/fp34/fp34-usb-ac97.jpg
It is probably plugged into the motherboard somewhere. Try plugging it into the soundcard directly if it is in the motherboard. Or vice versa if it is plugged into the soundcard.
-Alex
May 06, 2011 | Computers & Internet
Hey my rear lights have all of a suden stopped working are there a few things i can check myself to get them working again. the front ones are working fine and none of the back ones are but the bulbs seem...
Check your fuses (open the kick panel above accelerator pedal to access) If it's not a fuse you can get a test light for a few bucks at supercheap/repco etc.It has a needle which you push through the plastic coating on your wires to see if power is there.Try working backwards from there to check for broken wiring.
Feb 09, 2011 | 1996 Ford Contour
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
No Signal
hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Aug 18, 2006 | Compaq iPAQ Connection Point CP-2W...
HP JBL Platinum Computer Speakers Logo
134 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
