Question about SanDisk Sansa e250 MP3 Player
My sansa won't turn on - SanDisk Sansa e250 MP3 Player
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    Won't turn on
    Please give some more details.
    I suppose it's the problem that your Sansa e250 MP3 Player won't turn on.
    You could turn to Sansa official support.
    Jan 03, 2012 | SanDisk Sansa e250 MP3 Player
    How can I remove slotradio from my sansa
    i up greated my sansa fuze 8 gb music/ video player just wanted the sansa media player and it installed the slotradio firmware tried formatting the player with windows media player format just wanted the media converter cant ,t remove this slotradio from the menu image won,t erase anybody!!!!
    Apr 06, 2010 | SanDisk Sansa c140 MP3 Player
    The sansa clip got stuck on
    try contacting sandisk or something and ask them
    Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
    My device turns on but shows message ¨refresh database¨ it won´t do anything else, what can do?
    HI,
    Try these steps:
      STEP 1 - Reset the device
    1. Slide the Power switch up and hold it for approximately 20 seconds.
    2. Release the Power switch once the device is powered down.
    3. Turn the device back on.
    STEP 2 - Download and Install the Sansa Firmware Updater
    Jan 29, 2009 | SanDisk Sansa e260 MP3 Player
    My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
    turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
    There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
    Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
    My sansa clip screen won´t turn i can just here the music
    press the screen in it should work the wires internally are shorting
    Jan 04, 2009 | SanDisk Sansa m240 MP3 Player
    It wont turn on !!!
    My Sansa won't turn, and its been giving me a lot of difficulties since I bought it. It just turned off and like died. It won't turn back on. HELP!!!
    Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    254 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
