Question about Freezers
Freezer stop working ,it woul turn for seconds .hear a clicking sound and stop.
    Guru:
  • 1,524 Answers
Try installing a hard start kit.
Posted on Jul 14, 2010
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Unit not cooliing, all the fans are working and unit is clean
The click sound might be the motor trying to start. If it has problems tou have to replace it.
Feb 10, 2014 | True Manufacturing Countertop Glass Door...
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Freezer starts then stops
Either the start relay on the compressor is bad OR the compressor is bad.
Replace the start relay and find out which it is.
When you remove the relay you may see a burned spot on one or more of the relay terminals.
If so,it is definitely bad.
Apr 26, 2010 | GE 24.9 cu. ft. General Electric Chest...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezer problem fixable?
clean under freezer with vacuum, if frost free look under front louver panel(2 screws or snap in fit) for defrost-timer - use sraight tip screw driver to turn slot slowly till you hear click. wait to see if starts working properly, if not that mostlikely problem
Jun 02, 2009 | Freezers
Upright freezer stopped working
That clicking sound is your compressor tightening up(clixon switching on and off.). Pull the freezer out and feel the compressor. If very hot and not running, there is your problem.
Jan 29, 2009 | Freezers
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Sep 25, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
