Xerox Workstation Pro 2128 saying communication problem encountered and we have switch off and switch on again several times and still same problem & mesage appeared. Before that we have a drum cartridge A1 also which is empty as well as the transfer roller which is at 0. Will it after changing this it will work or not. Thank you to reply us urgently.
  • 1 more comment
  • ibrahimayoub Jul 14, 2010
    Thankyou for your reply. We have ask the Xerox technician to come and fix it. But before on last Friday the Xerox technician came andthen said when using his laptop he culd not get access to the hard disk then he said that hard diskis faulty and he said also that the network controller has burned or not working. Reason why communication error.Then Xerox technician told us that we need to change an dit will cost us a lot of money. So then I ask my IT guy in the ofice to cross check and he connected his computer with the machine and he got access with the printer and saw that hard disk is working and that the network controller seems to be ok and through the connection on his computer he saw that the machine is giving error message saying Replace CRU and we found that Drm Cartridge A1 and Transfer Roller are inished and we think that maybe we need to replace these 2 consumables of maybe at first just to replace teh Drum Cartridge A1 to see if it works. We believe that Xerox technician was not clear about what was wrong and think that he gave us wrong advice. Now we stated this to the Xerox techinician this morning and he will come later on today bringing the Drum cartridge A1 to se and then check again with his laptop.
    So your reply on the above would be most welcome to help us. Thanks a lot for your kind help
    President:
  • 1,070 Answers
Welcome to FIxYa
Sir/Madom
Here is Guide for Your Product Click here[Read it Carefully to Get Complete instruction about Product]
Service message Service "Communication problem encountered" and further postscript at the bottom Reset system by turning power off, then on, using the white power switch. Error code machine at issue, but the user can immediately see its interpretation. Literal translation - has detected a problem of communication, reboot the system by turning, then activate. Use for these purposes breaker White Power. Naturally the user performs the recommendation of machines, and of course anything useful in this case does not occur.
The first question that happened? Due to problems with power, crashes the device software, and MFP loses all its system settings. This problem often occurs after a physical power off for a certain period of time holidays, weekends, moving color MFP. The second question what to do? How to repair your printer?
Do not even think about any INDEPENDENT ACTION REPAIR MFP! Look only to the professionals. To correct the defect required spare parts and special-certified by Xerox laptop with a set of service programs. Even if you get these programs to work on conventional notebook they will not, and what procedures to run low, you still do not understand. But forget the machine completely. That in Xerox WC 2128, Xerox WC 2636, WC 3545 problems are solved using notebook, in which both contain "Tanker" service menu, just more complicated. MFP has two HDD. At one store the internal software system, on the other user data sent to print, scanned images, etc.
Hope you got it..Thanks for Contacting FixYa...
Posted on Jul 13, 2010
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Xerox workstation pro 428 error code 116-324
I did contact the Xerox support center and they did suggest the following fix:
reboot the printre --> pres the following buttons --> powersave + red stop button + nr 6.
This should empty the print memory.
Dont forget to remove all the printer jobs on the client computers.
Apr 30, 2011 | Xerox WorkCentre Pro 428 Copier
Xerox workcentre pro 40-communication problem encountered
Some connection is lose. One of the connectors to the main board may be loose. The communication it is taling about is the machine devices are not talking to the main board.
If you just purchased it you can call Xerox and they will send someone free of charge to fix it.
The number is 1-800-821-2797.
Does there happen to be a code coming up with the message? like an 03-888 ot 05-222?
Mar 03, 2010 | Xerox WorkCentre Pro 40 All-In-One Laser...
Workstation pro c2128 - communication problem encountered. reset system by turning off, then using the white power switch. this did work?
Hello ! This problem often occurs after a physical power off for a certain period of time. If you haven't done so, reboot the system by powering Off then On, using the white power switch. If not resolved, unfortunately the only solution is for Xerox to service it with a specially set up notebook, which contains a "Tanker" service menu. Parts may be needed as well. Hope this helps.
Oct 17, 2009 | Office Equipment & Supplies
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Command Workstation for fiery x15
xerox.com look for dc 3535 in support and drivers and the new command workstation is in there
Oct 27, 2008 | Xerox DocuColor 12 Printer
546 people viewed this question
k24674
jasbo
jasbo
