Question about Refrigerators
Whirlpool ET18PKXGW refrigerator. Freezer compartment leaks into refrigerator section when it goes into defrost cycle.
  • jonkeith Jul 13, 2010
    the water problem has been occurring for a very long time. I keep an aluminum pan in the refrig section to collect the water. The problem is not due to the humid air this time of year.
  • Refrigerators Master
  • 2,605 Answers
welcome to FixYa. Based on your description you likely have a blocked/frozen over defrost drain. This is actually quite common with this style of fridge you have.
You`ll have to pull up the bottom tray in the freezer and remove the back evap. cover as well to clear the drain...best done with a steamer or hot water, it will take some time. Careful not to damage the evap coils...or your hands, the evap. louvers are sharp.
There is also a repair kit for this issue, some proclaim it works others not. My experience is it always works...if installed correctly. It should be done by a qualified technician though.
The kit is # 819043 and available through "searspartsdirect.com". It will look like this...
Let me know if you require any further assistance. Hope that helps.
Thanks for choosing FixYa. Please take a moment to rate the solution I provided for you today.
Good luck.
macmarkus :)
Posted on Jul 13, 2010
    I have emptied the freezer, taken off the bottom tray and noticed quite a lot of frozen water. I have cleared that (several times now) and for a few days the freezer works fine. then it starts to leak again. It sounds like you are saying that I have to take something off of the back of the freezer compartment. Is that correct?
  • Mark MacDonald
    Mark MacDonald Jul 13, 2010
    Yes that is correct. You must also remove the back panel ( evaporator cover ) in the freezer section once the bottom is removed.
    Once that is removed you can actually reach the drain tube, this is the "cause" ( clogged with ice ) the water draining into the fridge is just the effect or if you like result.
    The drain kit I alluded to previously is what will be installed into the drain and the other part is simply a "heat sink" to prevent it from freezing over in the future.
    You must first insure the drain is completely clear until water can actually pass through right to the bottom where the condenser tray is located, otherwise it`s an exercise in futility.
    macmarkus :)
  • 6,826 Answers
There should be a drainage passage behind the back wall of the refrigerator that should drain any freezer's defrost cycle water to the drain pan at the bottom.
But, in your case there is either a blockage that makes it back up, or the routing of the water is going through a crack in your plastic in the back.
It can either be misassembled or actually cracked and damaged.
I would try to take the food out, put into another refrigerator, and defrost your refrigerator manually to try to see if doing this solves the problem when it goes back online.
Defrost for 24 hours manually can get rid of any build of ice that the defroster doesn't melt.
Unfortunately, this is a humid and hot time of the year when ice build up can occur in even the best of refrigerators, wreaking havoc.
Good luck on this repair.
The divider between the two compartments is warm
Check if ...
The condenser coils or base grille are dirty or clogged.
The motor has quit working.
Then ...
Clean according to the “Cleaning your refrigerator” section.
See “Your refrigerator will not operate” earlier in this section.
NOTE: The refrigerator temperature may turn from warm
to hot.
If not due to any of above, the warmth is probably due to
normal operation of the automatic exterior moisture control.
If still concerned, call the Consumer Assistance Center or
an authorized Whirlpool Service company.
Temperature is too warm
Check if ...
The air vents are blocked in either compartment.
This prevents the movement of cold air from the
freezer to the refrigerator.
The door(s) are opened often.
A large amount of food has just been added to
the refrigerator or freezer.
The controls are not set correctly for the surrounding
conditions.
Then ...
Remove any objects from in front of the air vents. Refer to
“Ensuring proper air circulation” for the location of air vents.
Be aware that the refrigerator will warm when this occurs.
In order to keep the refrigerator cool, try to get everything
you need out of the refrigerator at once, keep food
organized so it is easy to find, and close the door as soon
as the food is removed.
Adding a large amount of food warms the refrigerator.
It can take several hours for the refrigerator to return to the
normal temperature.
Refer to the “How the controls work” section.
There is interior moisture build-up
Check if ...
The air vents are blocked in the refrigerator.
The door is opened often.
The room is humid.
Then ...
To avoid humidity build-up, try to get everything you need
out of the refrigerator at once, keep food organized so it is
easy to find, and close the door as soon as the food is
removed. (When the door is opened, humidity from the room
air enters the refrigerator. The more often the door is opened,
the faster humidity builds up, especially when the room itself
is very humid.)
It is normal for moisture to build up inside the refrigerator
when the room air is humid.
  • Duane Wong
    Duane Wong Jul 13, 2010
    So, you're saying that it occurs even in the winter time.
    That indicates to me a serious gap in the drainage system,
    which requires disassembly of the back wall to find the problem.
    Wish you luck.
When roper freezer goes in defrost mode it leaks
Assuming this is a unit with the freezer on top of the refrigerator, the drain is plugged and must be cleaned to allow water to flow from the freezer cooling coil during the defrost cycle down to drain pan, located under the refrigerator (in the compressor compartment.) Follow the leak up to see where it is leaking into the refrigerator and start from there to locate and remove the blockage.
Oct 20, 2014 | Refrigerators
My bottom drawer freezer is accumulating a sheet of ice
Your defrost drain line is clogged or frozen so the defrosted water is leaking into the freezer compartment and freezing into a ice layer in the next cooling cycle. Get your defrost drain line unclogged.
Sep 16, 2014 | Whirlpool Refrigerators
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a whirlpool side by side refrigerator that is leaking and we can not figure out where the leak is. the pan is full of water.
empty out the freezer and remove the back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
