Question about Campbell Hausfeld 8GAL Air Compressor
Can't auto stop
The motor never stop even the pressure way over the cut out pressure. I thought it was switch, but even I detach the wires froo switch, the motor still run. The circuis inside the electrc control box is on anyway. where I can purchase the control box?
  • 36 Answers
How can the motor run if u disconnect it from the switch? as the main lead goes to the switch the the motor leads are off the other side of the powersurply?very confuseing as it shouldnt go regardless what wires you took off. i think you should find a wireing diagrame and rewire it.then decress the spring bolt and start it up, should stop
Posted on Jul 30, 2010
I have a a old Gibralco compressor when i cut it on it starts fine when it reaches desired pressure it stops and restarts until i kicks the breaker what can i try
i suspect that the start/run capacitor is faulty or the centrifugal switch in the back of the motor is faulty
have an accredited electrician check the motor , capacitor and the pressure control switch
the air leak at the head is a faulty non return valve in the compressor line to the tank
available at good tool shops for around $60.00
Sep 07, 2015 | Air Tools & Compressors
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Hi , I have a john deere Dual Stage snowblower 1330SE The electric Chute rotation won't work any thoughts?
Detach wires at the motor that turns it, have someone try to rotate while checking wires with a meter. Should have power, if not look for bad fuse or connection to the switch. If you have power to the motor check across the motor for continuity. Maybe motor has a stuck brush?
Feb 04, 2015 | John Deere Garden
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Need to know wat oil i use, coz the oil light is on
The oil light is not an indicator that the oil level is low, its is an indicator that your oil pressure is low.
A dirty oil filter will make your engine loose oil pressure.
Of course no oil in the motor will also cause no oil pressure.
If you have the correct oil level and a new oil filter, and your oil light is still on.
Check that your oil pressure switch/sensor is working.(your oil light wire will go to the switch/sensor).
If your oil level is fine and the oil filter is clean and the oil light switch/sensor is good and the oil light still comes on, that is a sign that your oil pump isn't working correctly, and would have to be taken apart to see why.
Check the simple and less expensive stuff first, hopefully it will be one of those
Dec 09, 2010 | kawasaki GPX 250 R Motorcycles
Motor burned up, replaced motor now it will not start. could it be the capacitor?
I just had an issue where I thought the motor burned up. It turned out that the red wire from the motor start capacitor to the Motor switch was poorly attached. It became detached midwash and when the motor was supposed to start next I must have got an arc of some kind and thought the motor had burned out due to the smell.
Check the red wire from the motor start capacitor and make sure it has not detached from the plastic wiring harness/pin plug that plugs in to the motor switch. Detach the paper face plate of the motor switch and make sure the connectors are not fried.
Oct 20, 2010 | Kenmore 22422 Top Load Washer
EC119SA less than one yr old just has started showing signs of low air volume. Was using it to clean off work bench, first blast of air was strong then quickly has very little pressure. The pressure gauge...
hi there, if there is enough air pressure present in the compressor the motor will stop,the pressure switch is working.if there is a good pressure at start then suddenly lost the pressure,there is no maintaining pressure to use but on the pressure gauge appear to be have a good or enough air pressure. check if the pressure gauge have enough air pressure the motor is stop,meaning the cut out limit switch stop the motor,if you loosen the air pressure from the valve until the cut in pressure attain or meet the motor will run again there will be a cycle process of differential pressure of cut in and cut out set up on pressure switch. checking the compressor,be sure there is a high pressure on compressor and the compressor motor is stop,shut off service valve and disconnect unit device / tools from the service valve. if the compressor have enough air pressure crakc down the service valve and observe the pressure until it run again the compressor motor,if the pressure maintain the pressure you need to clean the bench, the problem is the unit device/tool you use is defective, but if the maintaining air pressure in the compressor is lost due to malfuction of motor and the compressor engine. check the pressure switch, check the motor function by loosening the belt and run the motor w/o the compressor engine if it is tripping brought it to service center, check also the lubricant oil,if neccessary change oil.have a nice day and fix my rate thanks a lot.
Apr 20, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Mar 31, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
A/c unit
check the fan timer if equipped. check stat wireing and make sure it is on auto. remove wire on g from stat and motor should stop.check for power to motor and remove on control or wire at a time unit it stops running
Dec 28, 2007 | Weather King 12AJA4801AH Air Conditioner
Campbell Hausfeld 8GAL Air Compressor Logo
91 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
