Question about Gateway GT4022 PC Desktop
I have a gateway gt4022 running windows xp. When
I have a gateway gt4022 running windows xp. When I turn it on it doesn't boot - even to a bootable disc - it just sounds like it's cycling but nothing comes on - any ideas?
  • 1 more comment
  • Gary Woodruff Jul 13, 2010
    Please post any beeps or error messages you get (if any). Do you see anything on the screen?
    Please rate this solution if it has helped you.
    Thanks, Gary
  • springst Jul 14, 2010
    The blue light did come on but now it doesn't - only cycles on the CD Reader. I do hear the fan though. I'm leaning toward motherboard - any suggestions?
  • springst Jul 16, 2010
    No beeps, no error messages, the screen says no input - I checked the monitor and it works on another pc. Checked the power plugs inside (took static precautions) and turned it back on - now I get no blue light on the power button and the CD light blinks as it cycles - you can hear it trying to power up. I'm leaning toward trashing and getting a new one since this isn't the first problem - I had to replace the motherboard once a few years ago - After reading all the problems on this site maybe Gateway is the problem.
  • 3 Answers
Motherboard issue on these models
Posted on Feb 10, 2011
  • Gateway Master
  • 11,800 Answers
Probably hardware failure. To test that remove all disks and extra components and try again to boot into BIOS. If you can't then you will know for sure. If you can then take the opportunity to change the boot order and put the cd first and the hd second. Now connect an optical unit and try to boot in a bootable disk, preferably a Linux Live-CD. If you can then the hard disk is dead, replace it.
Posted on Jul 14, 2010
  • Azrael SRL Jul 16, 2010
    This looks like a power source failure. And when that fails it usually takes other components with it. Time for a new pc.
Were can i get a reset password disk
Download Hiren's Bootable CD, in it you'll fine the software to reset the password, it may be what ever operating system it is. and the Good thing about Hiren's Bootable CD is that you don't need to pay.
Aug 02, 2012 | Gateway GT4022 PC Desktop
I have a gateway gt4022 at first i had the power issue but after sometime it solved itself out i guess......but after that i started getting another problem which after the PC boots into windows.....the ...
The screen goes fuzzy because the video chip has failed. Since this is an onboard one you will have to replace either the motherboard or the entire pc if you don't know how to do that .
Jun 06, 2011 | Gateway GT4022 PC Desktop
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
I have a Gateway 507 GR Windows XP Home Edition. Windows does not load/Boot, Error message "Not found or corupt. I can hit I think it is F-2 or F-12 (I forget) and go to the BIOS settings, and try and...
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device.
after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Mar 01, 2010 | Gateway 507GR PC Desktop
I have a gateway 835gm and when i turn it on. It wont go pass the windows xp screen. it just keeps re-booting.
If you have a windows boot cd, use it to get to the first boot screen where it asks you if you want to repair it or install XP. Try repair first and run check disk. If this doesnt work, then instead of pushing repair, press ENTER and do a reinstallation repair.
If you dont have a windows boot cd then you can download this ISO and burn it to a CD. It will boot and allow you to have a lot of diagnostic programs.
http://www.ubcd4win.com/index.htm
Go to this site and make a bootable cd. Once you have made it, go to the diagnostic category for hard drives. Run check disk first, then run the other ones if necessary. If it is a problem with the fileing system, then one of these tools will probably fix it.
Jul 21, 2009 | Gateway Computers & Internet
Gt4022 boot problem
if your motherboard is getting power .try changing the boot sequence
Jul 27, 2008 | Gateway GT4022 PC Desktop
Gateway GT4022
Is Eithernet card on board or a card. If a card, turn off computer, remove card, boot up shut down reinstall card and XP or Vista should find drives and install.
Jun 23, 2008 | Gateway GT4022 PC Desktop
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
Gateway computer reboots automatically
To get into Safe Mode, just as the PC starts press the F8 key on the keyboard every 2 seconds. Windows will open a Dos like screen where you can pick how you want to start windows. Safe Mode is listed there. If this does not help you find your problem I can tell you that windows is confused (startup files). Two ways to fix this. One is to run system restore. 50/50 chance that will work. Two put your Windows CD in the cdrom & boot to it. Allow windows to repair it's self. You will not loose your data that way.
Please vote...
Feb 01, 2008 | Gateway GT4022 PC Desktop
Computer won't boot up...
booting files corrupted try to boot by inserting windows 98 bootable cd or windows xp bootable cd
Dec 03, 2007 | Gateway GT4016 Desktop PC
Gateway GT4022 PC Desktop Logo
182 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
