Question about Brother MFC 7840W Printer
Still reads toner low, replace toner with BRAND NEW Brother toner cartridge installed
    President:
  • 405 Answers
With the front cover open (where the cartridge is installed), press the clear/back button then press star 00 (*00), then close the cover.
Posted on Jul 15, 2010
  • noleavitt Nov 18, 2010
    It solved my problem. Thank you very much!
TAPE OVER THE SIDE WHERE BEAM READS TONER WORKED FOR OUR BUSINESS
Posted on Aug 11, 2010
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
I just changed the toner and the printer does not print.
If u have the CD of tht printer , u just delet tht printer from the Devices and printers settings. And re installed it
Aug 14, 2012 | Brother HL-2040 Laser Printer
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
I get black streaks on the pages I am printing
It sounds like you need a new drum, look here for some pricing. To replace the drum follow this guide on Brothers website.
Mar 05, 2011 | Brother HL-2040 Laser Printer
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Cartridge error msg
You have a bad toner cartridge or a poorly remanufactured toner cartridge. This condition called "false toner low".
Mar 12, 2009 | Office Equipment & Supplies
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7840W Printer Logo
1,166 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
