Xerox Workstation Pro 2128 saying communication problem encountered and we hav eswitch off and switch on again several times and still same problem & mesage appeared. Befor ethat we have a drum cartridge A! also which is empty as well as the transfer roller which is at 0. Will it after changing this it will work or not. Thank you to reply us urgently.
  • ibrahimayoub Jul 13, 2010
    Thank you for your reply. WHat if after changing the Drum A1 the problem still arises.
    Here when we switch on and switch off the problem still continues
    Hi Infact in the Xerox Pro C 2128, we cannot access the controlpanel at all as it only display onthe small screen "communication problem encountered" is this normal? Normally when the Drum Cartridge is empty you can still print and you can still access the control whereas now not. You just see the Xerox logo on the small screen then it continues to loan and after a while you just see a white box appears saying "communication problem encountered". Please tell me if this is normal
    On the otheside we 'll buy a drum cartridge A1 tomorrow morning and replace it as now it's 6 p.m in Mauritius the Indian Ocean as the Xerox shop is now closed.
    Do you think after changing the Drum Cartridge A1 the machine will work again? thank you to reply
  • 677 Answers
Hi,when messages like "Communication problem encounter",is usually caused by The cartridge.When replaced it will work properly.
I would contact the people over at GM Supplies. They only deal with Toners, Inks, Drums, Printers and Copiers -
The Xerox Page is: http://gmsupplies.com/products.aspx?ID=16
If you call they are extremely knowledgeable and considerate, They will surely help with the best recommendations.
Good Luck .
Posted on Jul 13, 2010
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Xerox workstation pro 428 error code 116-324
I did contact the Xerox support center and they did suggest the following fix:
reboot the printre --> pres the following buttons --> powersave + red stop button + nr 6.
This should empty the print memory.
Dont forget to remove all the printer jobs on the client computers.
Apr 30, 2011 | Xerox WorkCentre Pro 428 Copier
Xerox workcentre pro 40-communication problem encountered
Some connection is lose. One of the connectors to the main board may be loose. The communication it is taling about is the machine devices are not talking to the main board.
If you just purchased it you can call Xerox and they will send someone free of charge to fix it.
The number is 1-800-821-2797.
Does there happen to be a code coming up with the message? like an 03-888 ot 05-222?
Mar 03, 2010 | Xerox WorkCentre Pro 40 All-In-One Laser...
Workstation pro c2128 - communication problem encountered. reset system by turning off, then using the white power switch. this did work?
Hello ! This problem often occurs after a physical power off for a certain period of time. If you haven't done so, reboot the system by powering Off then On, using the white power switch. If not resolved, unfortunately the only solution is for Xerox to service it with a specially set up notebook, which contains a "Tanker" service menu. Parts may be needed as well. Hope this helps.
Oct 17, 2009 | Office Equipment & Supplies
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Command Workstation for fiery x15
xerox.com look for dc 3535 in support and drivers and the new command workstation is in there
Oct 27, 2008 | Xerox DocuColor 12 Printer
42 people viewed this question
k24674
jasbo
jasbo
