Question about Dell OptiPlex GX260 PC Desktop
I have an Acer Aspire one and it won't let me change my resolution off of 800x600 I have windows 7 ultimate x64 (32-bit right?) i need help to get my 1024x600 res back.
  • Dell Master
  • 3,289 Answers
Generally - you simply need to right-click anywhere on the desktop that does not have an icon present, and select "Screen resolution". Adjust the slider as needed to obtain the desired resolution. If the resolution desired is not available, choose another that is close.
Digging deeper, you might want to investigate the "Advanced settings" to make sure that you've got the correct drivers loaded in the settings for both the "Adapter" and "Monitor" tabs.
Lastly, "Windows Ultimate x64" is the 64 bit version of Windows. The 32-bit version is referred to as "Windows Ultimate x86" If there are both 32-bit and 64-bit drivers available for your Aspire, make sure you get the correct version 32-bit = x86 and 64-bit = x64. The "x86" tag came from the Intel processor line up where the "x" represented the generation (8, 16 and 32 bit CPUs) and the "86" were the last two digits to indicate the instruction set used by the CPU like this:
8086, 80286, 80386, 80486, etc.
The 64 bit CPUs are not x86 family processors, so they do not carry the x86 tag. Please rate this reply if it was helpful to you - good luck!
Posted on Aug 03, 2010
Acer al1780w drive
You need to download a better driver. But download it from the card manufacturer, not from windows.
Feb 13, 2018 | AOC Computers & Internet
Want to create a 800x600 32 bit window
XP - Right click desktop > Properties > Resolution.
Win 7 - Right click desktop > Resolution.
You need drivers if you can not adjust settings.
Apr 08, 2013 | Computers & Internet
Acer aoa 150-1570 netbook, win7 ultimate CLEAN install, dual boot to Ubuntu 11. Orig HDD replaced with a clean 500GB HDD, Clean Installed W7U 32bit from Ext ODD Boot. The screen is partial [an 800x600...
akberztech
Note sure if you have the steps to manually change your display settings in Windows 7 but the link below will help you do this.
http://www1.fixya.com/support/r4290529-change_windows_7_display_settings
After checking these steps and you still have trouble look to see if Sony has a Vista 32 bit driver for your computer because in most cases the Vista drivers will work with Windows 7.
Let me know if you have any more problems or quesitons
Issken
http://www.fixya.com/users/issken
Sep 04, 2011 | Acer Aspire One AOA150-1570 Notebook PC
I AM HAVING ASPIRE 5610 LAPTOP, RECENTLY I CHANGED OS, XP TO WINDOWS 7 ULTIMATE. BUT WEBCAM IS NOT DETECTING. PLZ GUIDE .
try on this page:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/Acer-Aspire-5610-Webcam-Driver-696.shtml
this driver is for Vista, but it could work.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | Acer Aspire 5610-4648 Notebook
I have acer aspire one zg5 windows xp pro then i upgraded it to windows 7 ultimate and now it dosent have webcam driver and microphone diver etc please help me get the drivers for windows 7 ultimate my...
did u go to Microsoft.com and run the windows 7 compatibility tool if acer.com doesn't have the driver then u will have to find out what the manufacture of ur camera is and go to their site and see if they have it
Jan 28, 2011 | Computers & Internet
Aspire 7715z touchpad not working oc windows 7 ultimate
most likely a drive issue. check the acer website and download the latest touchpad driver for Windows 7, make sure to get the one for the correct edition (32-bit/64-bit)
Dec 31, 2010 | Acer Aspire 7110-2069 Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
I have an older Acer Aspire 3000... it recently became to cluttered and when I tried to reformat loading windows 7 ultimate, it stopped saying it couldn't find everything it needed. I'm fairly certain its...
Not all systems are supported by Windows 7. Infact many items that were supported by vista are not supported in windows 7.
looking at your system specs you woudl originally have AMD Mobile Sempron 3000+ / 1.8 GHz , 256mb ram and windows xp home as your original.
this system does not meet the minimum requirements to run Windows 7 Ultimate or Windows 7 at all.
minimum specs for windows 7 are
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • i do not recommend a 1ghz system. i would recommend a 2ghz or better with 2GB of memory for a basic version
    Feb 11, 2010 | Acer Aspire 6930-6771 Laptop
    The screen and everything on it is enlarged very big and even after changing the settings and doing a system restore it won't change
    CHANGE RESOLUTION OF YOUR MONITOR. RIGHT CLICK ON EMPTY DESKTOP, SELECT property, SELECT display, AND resolution. INCREASE RESOLUTION TO 1600X1200 OR SIMILAR. PROBABLY IT IS SET NOW AT 800X600.
    Oct 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
    Dell OptiPlex GX260 PC Desktop Logo
    122 people viewed this question
    Alun Cox
