Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Hi Do Phillips Magnavox 7302XVB 60" made in 1999 have a picture tube? When I start up my tv the picture fades in and out and when it heats up it pops in and works fine. Now it has completely went out with no picture. Are there tubes for this problem and what would this cost to fix a ballpark figure? Thanks Barbara
Barbara, did you get this fixed?
Posted on Oct 04, 2010
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The color seems to be fading. NOt a clear picture.
Likely the picture tubes are getting weak from old age. Not much you can do about this.
Mar 30, 2009 | Televison & Video
Phillips magnavox 50" projection TV shows a light picture
it sounds like the tv is going out. you might call a repairman before it does so you dont lose the tv.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Phillips Projection TV - Model 9P5511C
Common problem with the model. Check the site www.TvRepairKits.com. They have a fix for the shrinking and expanding screen problem.
Sep 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60... Problem
You need to change the coolant in the CRts ( picture tubes) you can get the Phillips coolant replacment kit at the following link with the coolant and the instruction CD with step by step instructions on how to do the replacment with pictures. Its listed under the repair kit category. Heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
My Philips Magnavox 9P5511C102 color is faded and not clear. The colors seem faded (off) tv is not clear, like is got static, and picture is shaky. I have tried to fix using the Main Menu already. Out of...
update the firmware/software if possible. my 60" has a USB slot on the right side. also you can download the manual from phillips http://www.support.philips.com/support/html/index_us_en.html#../~scripts/xsltransform.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=us_en||mode=cats||item=TV_GR&xsl=subcatalog.xsl
my phillips 60PP9200D/37
Apr 26, 2008 | Philips Magnavox 9P6034C 60" Rear...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
