Question about Toshiba Satellite L305D-S5895 Notebook
I need to repair the power socket, how does the case come off?
    Novelist:
    Champion:
  • 226 Answers
The DC harness on this model is a known fault. Toshiba UK will repair this power harness free of charge even if the unit is out of it's warranty period. I see yours is the US unit but I would imagine it is a free service over there too. Contact Toshiba customer support, explain the DC harness is loose inside your system and ask if it is a free repair due to being a known fault on that range of laptops. Hope this helps,
www.PuterCare.com
Posted on Jul 14, 2010
The pin that u put the charger in has went back in the laptop. how to open it to get to it to fix it.
The power socket on a laptop is usually soldered directly to the mainboard. Sometimes the socket is on a seperate smaller daughterboard or on a cable that connects to the mainboard, but usually this is not the case. Opening the laptop to perform this repair can be very trick and time consuming. I would certainly not recommend an amateur attempting this repair as usually the entire board needs to be removed, the socket de-soldered and a new socket soldered in place. Not for the faint hearted! If you wish to provide laptop model details I may be able to provide the screw locations etc and disassembly guide.
May 29, 2011 | Computers & Internet
My Y530 wont come on.....I checked the power supply and power is coming to the battery via the ac plug but when I hit the power button the screen stays dark. How do I fix this?
Hi. Are the light indicators on the computer turns on when you press the power button. If none, then this could be a case socket issue. Case socket where you insert the power adapter to your computer is somewhat loosed. Socket has no physicla contact to the motherboard that is why computer is not getting the power. You may call Lenovo Tech support if you want this issue repaired. Phone number is 1-877-453-6686 then press option #3
Sep 14, 2010 | Lenovo IdeaPad Y530-5243U
Toshiba L300 Case Repair !
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite a215 loses connection with power cord
The fault could be the adapter plug (a broken wire at the plug) that connects into the laptop or a faulty power socket on the laptop. In most cases it is the power socket on the laptop, it could be just a dry solder joint in the circuit board where the power socket is soldered on the motherboard or the power socket is faulty and therefore needs to be replaced.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 06, 2010 | Toshiba Satellite A215-S4747 Notebook
My whirlpool washing machine wont turn on. I checked the fuse and the socket which are working perfectly well. It doessnt seem like there is any power in the machine.
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 17, 2009 | Whirlpool Washing Machines
The dc power plug is broken
Yes.
Is the connector on the power adapter that plugs into the laptop?
If so, this is an easy repair, purchase a new connector from electronics parts shop, cut off the old connector and solder the new one on the end of the cable. MAKE SURE YOU SOLDER THE CONNECTIONS TO GIVE THE CORRECT POLARITY ON THE CONNECTOR, OR YOU WILL DAMAGE THE LAPTOP.
If the power socket on the laptop is faulty, this repair is more difficult. The socket may only need resoldering on the motherboard or in the worst case a new socket replacement. Either way the laptop need to be dismantled to get at the power socket.
If you don't feel you can handle this, get it done by a computer repair shop or a techo friend.
May 28, 2009 | Computers & Internet
HP 2610 won't turn on. Power cord problem?
If there is no power at all test a different power cord. If there is a power adapter in the middle you can test DC voltage on power adapter.
Sometimes the power socket on the printer is bad, in that case you need repair service.
Test also the printer on a different socket.
Apr 28, 2009 | Office Equipment & Supplies
Need to open Advent 7072 case to resolder power jack socket...How?
This is something that should be left to a professional. A local repair shop should be able to handle this task easily. but if you insist you can try here
Apr 17, 2009 | Computers & Internet
How to open the case of a compaq 1685
Sorry, I don't think you can replaced the socket by your self, it not just because you even don't know to open it, it also need soldering skills and find correct socket can be fit in the case( must same one used for your motherboard.)
Must take whole motherboard out of the case if you want to replaced the power socket. That's not DIY, that's my job.
Nov 16, 2008 | Compaq Presario 1685 PC Notebook
Hard disk power Socket
If its just a case of the power socket broken..
I am able to recover this problem - Where are you located.
Depending on your location - will dictate the next steps..
Aug 06, 2008 | Computers & Internet
Toshiba Satellite L305D-S5895 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
