Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Put new belt on ground drive, but gear shifter only goes to 2nd gear as it is pushing against the new belt. Should the gear shifter be against the belt? Does the clutch tension pulley need to be adjusted? It is a weedeater 42 inch 13hp model hdt1338a.
    Sergeant:
  • 200 Answers
No it should not be against the gear shifter look over and try to rearrange.You may have to turn a bolt or two.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Poulan continually throwing drive belt
adjust the belt tensioner properly
check that the pulleys are in alignment
Apr 16, 2017 | Poulan Garden
97 Camaro z28 automatic shifter
It has second gear start. To activate and provide extra traction when pulling out of snow and muddy ground. z28 have positive traction rears.
Jul 27, 2017 | 1997 Chevrolet Camaro
How to adjust gear selecter indicater
The bushings in the rod that goes from shifter to transmission need to be replaced.
Apr 24, 2014 | Ford F-150 Cars & Trucks
Why is my shifter hard to shjft from park to any gear?
your having a problem with the shift interlock cable not releasing. need to check power and ground at the solenoid near the shifter, may be a broken wire.
May 23, 2012 | 1997 Toyota Land Cruiser
I have a hobart a-200 mixer that had the brass drive gear go out. I rebuilt the transmission and used a parts breakdown to clean out and rebuilt the whole tranny. Now I have no 1st gear. Under a load...
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
May 20, 2010 | Hobart A200 Stand Mixer
Car quit running while driving it wont start back up. it has fire,fuel pump on engine turns over i have 2 pieces broke in gear shifter area 1 i hold down lever it releases my key, on the right of shifter...
Buy yourself a new serpentine belt - its slipping on the alternator and the battery isn't getting enough charge.
If yours is an automatic the damage to the shifter may be preventing the car from starting - If the car thinks that it is in any gear other than P, it may not start.
Aug 26, 2017 | 1998 Ford Contour
`02 saturn sl 5 spd: grinds 2nd gear
well it got stuck originally right??might be time for a rebuild the cable does need the right amount of tension to push and pull,the linkage may need proper adjusting as well
Nov 24, 2009 | 2002 Saturn Sl
1999 honda prelude manual transmission isn't disengaging all the way when i shift, sometimes locking the shifter in gear or not allowing me to up or down shift. I know my master and slave cylinders need to...
This depends as dose it do it when cold or hot.
2nd when you push in pedal and put in gear dose it go in clean or hard to select 3rd can you hear a grinding noise when pushing in pedal and noise goes
when you take you foot off the clutch pedal IF so then its the thrust bearing on clutch REPLACE ALL .4th if you push in clutch pedal and select a gear and let the clutch out if drive right out (replace)
Sep 27, 2009 | 1999 Honda Prelude
Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
My dryer needs a new belt. I opened the front panel and removed the broken belt but I am not sure how to put on the new one. I know it goes around the drum but does it go in the middle or near the back...
Cheryl the belt goes in line with the pulleys. 1st Put the belt around the drum. 2nd put the belt around the pulley on the motor. 3rd pull down on the idler pulley and set it so that is pushes on the back side of the belt. Remember the ribs on the belt go against the drum. When done the pulley will take up the tension on the belt. Hope this helps.
Aug 09, 2008 | Dryers
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
231 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
