Question about LG WM-2277HW Front Load Washer
Water is not drining out
After washing the machine stops and not drine out the water and not spinning
    President:
  • 1,382 Answers
This kind of drain problem arise if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine.
Thank you !!
Posted on Jul 13, 2010
I can't get the bottom (tray 3) paper drawer to open.
turn off the machine. Go the rear of the machine and locate the hole at the bottom near third draw insert screw drine should release the draw
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 12, 2013 | Konica Minolta Seal for Bizhub 500 420 363...
I was given a kenmore, Lady kenmore ultra fabric care washer by my girlfriends mother. It worked fine, we oved it, all hookups seem to be correct, hot water is hot, cold is cold, I was able to do one load...
I had this same problem. I hired a repairman, which I highly recommend you do too. He found that the tub's base was corroded. The agitator wouldn't properly spin, and that had something to do with it ability to drain properly. My clothes were coming out sopping wet. He replaced the tub (at a cost of about $450), and then washer was as good as new. He said that washers and dryers that are made now aren't made nearly as well as these oldies. He said it should be in good working order now for the next 30 years.
Nov 08, 2010 | Kenmore Washing Machines
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Just shuts off while drining
check if the electrical system suply to ecm is eratic if so get an auto elect tech to help you
Aug 08, 2009 | 1995 Buick Park Avenue
No water to ice maker or despencer
Since you said it was "used" you should check the water filter if so equipped. It could be plugged. Also, and obviously, be sure the water to the unit is turned on.
I'd look for a plugged water filter first. Check the manual for the location (usually near the bottom front of the appliance) first.
Try these steps first.
Apr 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Filter cleaned, re-set computer, still F2 error
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel (three screws along the bottom panel). There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM-2277HW Front Load Washer Logo
260 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Oloyede Monsuru
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
