Question about ASUS P4VP-MX Motherboard
I took up my micro processor, put in again, my pc turn on and stuck on the page where ther is photo asus p4vp-mx. it tells press del to enter setup, when i press del, no respond, plz help
  • k_ramsaha Jul 13, 2010
    i have already cleaned it properly, but when i put it, it starts and there is the same problem. i have 2 pc at home, ive checked, on the other pc, i removed the processor the the other pc also, cleaned it and put it again, but for the second pc, it is not even turning on now. there is a 1 and 2 beep sound that comes....
    have i damaged both microprocessor, or there is something that should be done!!! plz help me, ive something important to be worked out, and both of my pcs are down
  • 35 Answers
Well, i think your processor or fan(on the processor) might not fit correctly. just Remove the processor and put it back after cleaning it. Try It Then Give The REsponse.
Posted on Jul 13, 2010
Can't enter bios page. I have a newly built pc (first time) with a asus 8h61-mx series, and when I turn it on, it will not ener bios page when i press F2, del or enter. Any ideas?
First off, on the ASUS website it says to try holding down DEL when the computer turns on. If that doesn't work make sure you have a PS/2 keyboard instead of a USB keyboard, if that works with a ps/2 keyboard then you'll need to turn on USB keyboard support or similar. If that doesn't work, try clearing the cmos, their should be a jumper, and a battery. Put it to clear with the jumper, and remove the battery. Then put it back, and move the jumper back. It should throw a error message saying the cmos and/or bios was reset, and will tell you to press a key to go to the bios.
Sep 14, 2013 | Computers & Internet
My MOBO is ASUS P4VP-MX. My bios fails to start. I reset my pins for bios the computer will run but when I restart again it will gave message that that BIO checksum failed. Is this a battery failure. I...
This error is not the same as a cmos Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 02, 2011 | Intel ASUS X Series Motherboard P4VP-MX...
I am having asus K8S MX motherboard with amd2800+ processor. when connecting sata hdd it is dtecting in raid mode only .what is the solution to read the sata hdd in normal mode of booting.the raid is...
hi! are you having problem with sata booting system?pls try this solution,
first turn on your computer,and press del when the setup system appear try to look for advance settings or ferephiral setting and look for the sata setup,turn disable setup to enable or on.and press f10 to save setting,
hope this will turn your sata boot to normal mode,,,:)
Dec 07, 2010 | ASUS K8S-MX SIS 760GX CHIPSET SERIAL...
My p4vp-mx asus motherboard has no audio sound, i am using xp professional service pack -2 operating system . please solve it .
First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
Oct 07, 2010 | ASUS P4VP- MX VIA P4M266A UATX P4/...
Driver for Windows7
please install PC Inspector
May 05, 2010 | ASUS P4VP-MX Motherboard
How do you rest the bios on a ASUS p4vp-mx mother board
it has a coms jumper in side coms battery 1-2 jumper normal position 2-3 clear coms choice 2-3 then *********** board reset
Nov 22, 2009 | ASUS P4VP-MX Motherboard
On a pc that I use only as the connection for a printer, i am getting a dark blue screen that says:ASUS P4VP-MX Del to run setup. However, it will not respond at all. Turned off computer and got same...
If you still have your manual open to page 1-15 section 1.11
Set the bios jumper to pins 2&3 for a few seconds. Than move the jumper back to pins 1&2 (Normal). Boot your system & enter the bios menu. Reset all your settings, save & exit. If you still receive a blue screen chances are there is an issue with your hard disk drive or another device within the system. You can also try pressing the F5 key during boot up & choose Safe mode with command prompt. C:\space fixmbr press enter
If you are unable to do anything you'll have no choice but to reinstall windows. Blue screens usually show an error message of sorts.
Mike
Oct 03, 2009 | ASUS P4VP-MX Motherboard
ASUS P4VP-MX display problem
If I understand you right, your display is not coming on with your new hardware. Try the eliminaion process:
take out the new things. Install them one by one, and try booting each time you install one. If that passes, turn off and install the next one, until you isolate the one failing. Once you know it, installit properly or come back here for help.
Feb 18, 2008 | ASUS P4VP-MX Motherboard
ASUS P4VP-MX Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
