Question about Sony Playstation 3 (PS3) Console
Ps3 the texture shoots out lines and sometimes goes blink and sometimes turn green
  • rubberball49 Jul 13, 2010
    ps3 texture shoots out lines sometimes turns green or blink
    thanks so much
  • 6,784 Answers
HI. If this is a constant issue that will occur with every game you play, I would recommend to replace the main AV cable. Once this is done, try to play a game and observe. If you experience the same issues with the newly purchased AV cable, this will confirm that there are GPU core issues(solder breaks near GPU socket joints or A/V cable module internal break points). This can only be repaired by a certified Sony tech. You will need to send the unit in for repair, in this severe case. Contact Sony for a repair ticket.
  • NOTE_ IF this unit is still under warranty, I would advise to not open the console. This would void any coverage that may exist. Try the New A/V cable first and unplug the unit for five minutes. This is essentially heat related, so if the new cable dose not work; Contact Sony, asap.
Posted on Jul 13, 2010
    President:
  • 1,561 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns on green light for 5 seconds then goes to a blinking red light and won't work. Help me please
You got YLOD dude. Either call Sony about fixing it, or you can do it manually, just search on Youtube YLOD fix or something along those lines.
Nov 02, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Turn power on and the light goes from green to blinking red.
you have the yellow light of death.. go to youtube and search for that and there are some self help videos.. basically u have to take the whole machine apart and reheat the cpu and gpu chips
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Disc stuck and then Ps3 system when turned on goes from green to yellow then blinking red
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
May 06, 2009 | Video Game Consoles & Games
Ps3 wont start up
how long have you had the ps3 i think mine crashed or fried
Oct 26, 2008 | Sony Playstation 3 (PS3) Console
Sharp 56DR650 shows power but wont turn on, Sometimes it turns on
That's error code 32. Indicates lamp trouble or failure. The system will shut down automatically.
Aug 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Playstation 3
Check the Hard drive .Sometimes a blinking red and green canbe a hard drive failure.
Are you sure the power sipplier you got is new??
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
