Question about ViewSonic VX2235wm LCD Monitor
Totally black screen during start up of the VX2235wm monitor. Only after several attempts (abouit 6 - 8 times) the boot up screen appears and from there on everything works.
    President:
  • 2,923 Answers
Try to connect the monitor into a different computer. If the monitor works on different computer, then the problem could be within the video or graphics card. It could have a problem or it could be loose only.
Open the CPU case of the problem computer and locate the video card. Pull it out and clean by removing the dust using a clean cloth. Wipe also the gold plates and connects to the video card slot. Then re-seat the video card to the slot.
If the same problem occur after cleaning the video card, try to uninstall and re-install the video card driver. If that did not help, try to insert the card into an available video slot (if there is), or might as well, install it in a different computer just to test the video card.
If you prove that the problem is the video card, get a new one that is compatible with your computer.
BUT if the monitor did not work on different computer...check the power cable and see also if there's a power light. If the power light is ON, but no display, try to adjust the brightness.
If the power light turns orange or blinking, then it's not getting a signal, you may need to change the cable, or the back light of the monitor could be busted. You may consult a pro regarding this problem.
Thank you and good luck!
Posted on Jul 13, 2010
  • hiltonmedfor Jul 13, 2010
    I have checked all that have been suggested with the exception of connecting the monitor to a
    different computer, however I did connect a different monitor to my computer and all systems work as
    startup boot up etc. work perfectfully.
  • hiltonmedfor Jul 14, 2010
    The black screen on startup problem still persists.
    Hooking up another monitor to the computer works perfectly. I should mention that the mother board
    is the Asus P5LD2-VM which carries an onboard graphics accelerator and is working perfectly with
    with another monitor.
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
My monitor boots up with computer, but turns black when it gets to the desktop. if i turn the monitor off, then on again, it stays on for 2 seconds then turns black. can someone help me?
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Nov 17, 2011 | ViewSonic VX2235wm LCD Monitor
Starting trouble...
problem with power supply section..
May 17, 2010 | ViewSonic VX2235WM Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Laptop black screen during boot, then normal in Operative System
is it affecting your pc
you can change the bootup display time if you want
but I would leave it as is if your system is not affected by it
Jan 20, 2009 | Dell Inspiron 9300 Notebook
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Monitor is failing to start although power is on
Sounds like you've got some blown capacitors on the internal hardware of the monitor.
Unless you are a seasoned computer hardware expert or electrical engineer I'd recommend you replace the monitor.
The capacitors that are blown are likely controlling the power aspect of your monitor, and aren't totally defective yet.
Most computer shops would not be able to repair your issue, due to lack of skills related to monitor repair. So you're going to find replacement the easiest / cheapest solution.
Of course you can try to ride out the problem as long as you can. But it will get worse over time.
Jan 08, 2008 | Xerox XA7-192i 19" LCD Monitor
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
57 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
