Question about Frigidaire FWS833A Top Load Washer
Water comes in and goes straight out
The washer will not fill up or agitate. the water comes in and goes right out. What is wrong
    President:
  • 1,430 Answers
The problem is the pressure switch has failed. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available. If you need help with accessing try this link http://appliancehelponline.com/toploadcabinet.html
Posted on Jul 13, 2010
Maytag top loading washer goes straight to agitation, won't fill with water.
you may find that the water sensor is not working as it should, unplug the machine take the back off locate the small 5mm pipe going upwards take it off and blow gently into it you should hear a click and one when you release the air, if so then the place you took it from is blocked, clean it out with a pipe cleaner or metal rod replace the pipe and rear panel and run the machine again, try to make Shure that you always fill the machine to its recommended load to prevent unbalanced loads eric
Jan 11, 2018 | Maytag Washing Machines
Water is coming in through the entry hose and running straight out the drain hose. No agitate, no spin, just constant water. Happened after I tried to wash three towels & got an imbalance alarm. R
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Nov 08, 2013 | Haier HLP21E Top Load Washer
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Sep 01, 2009 | GE WJSR2080V
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
Frigidaire FWS833A Top Load Washer Logo
244 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
