Question about IBM ThinkPad T30 2366 Notebook
Laptop battery light on but display not show - IBM ThinkPad T30 2366 Notebook
I cant get my battery to charge
Posted on Aug 31, 2010
Screen wont light up with new batteries?
Hi Wallace, The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
https://www.youtube.com/watch?v=2zby6_IK3kg&nohtml5=False
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 01, 2016 | Computers & Internet
What's your question? my proline laptop is not showing up the screen but it does show that its charging but doesn't show up the screen
That could be many problems. what your telling me is that u see the charge light when u charge it but when you turn it on nothing happens? this could be a number of things. I would hook up a monitor and see if anything shows up on the monitor if the laptop boots. if something does show up then its your laptop display cables that are bad.
Try This
--> First turn your computer off by pressing and holding down the start button. Next unplug the computer and then remove the battery. Press and hold down the start button for about 60 seconds. Release the button and plug in the computer. Press the start button and the display should return. Replace the battery. If this does not work, try it again up to four times. No results usually indicates a bad mother board. Hope this helps.
Mar 05, 2016 | Computers & Internet
Why does my ASUS laptop have no display? The fan and optical drive are working.
Do you have an HDMI cable to hook it up to a TV with? If so, try that. If it works, try updating your graphics card (I can show you how if the cable works)
Mar 25, 2015 | ASUS VivoBook S550CA-DS51T 15.6"""
I have a samsung R620 laptop but the laptop is not booting but the battery and ac adapter are working properly on the system because the battery light shows or indicate tha the battery adapter is okay but...
By pressing power button it is powering on or not if yeas the display light is comming or not? if yes then what is the bios error code please check. If not powering on then remove the battery plug in power adapter and press power button if not on then it is hardware problem go to service centre
Sep 13, 2017 | Samsung R620-64BR Laptop Computer
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Sep 25, 2013 | Gateway Computers & Internet
Laptop does not power on but show battery light when connected to power
The battery, the maindboard, the power circuit everything is possible. Try to remove the battery and power on
Jan 29, 2013 | Computers & Internet
Was having an intermittent problem with the laptop not charging/ starting. Replaced the power adapter and the power jack still having the same issue. When the laptop is plugged into the charger the battery...
Though your observations are explained well, I just want to clarify once again.
If you leave the adaptor plugged on for charging does the battery get charged up to display or show on display in the power options when switched on that the battery is fully charged.
Now if the adapter is removed does the laptop last much on the battery or does it drain off easily? If so the battery is bad and must be replaced.
Also if you are able to check the voltage on the battery terminals of the laptop and it shows a good reading then the battery is a suspect.
please check the link below for some tips on the power adaptor.:
http://www.fixya.com/support/r5164850-laptop_power_supply
Aug 20, 2011 | Sony VAIO VGN-CS320J Notebook
Battery light dosent work during charging or fully charged. Light comes up at times. battery level is either not indicated properly
In most models the battery light is displayed when it is charging with a possible blinking when it nears charging and it cuts off when the charge is full.
So if your laptop shows that the battery is charging in the task bar- bottom right, then you can ignore the issue unless your laptop is in warranty and it can be done free of cost.
If you open power options in the control panel the charging will be displayed , if this show Ok then the fault is the hardware circuit issue on the mother board power section.
Jan 22, 2011 | Computers & Internet
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
IBM ThinkPad T30 2366 Notebook Logo
49 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
