Error message add toner follow instructions for adding toner. The toner doesn't need replacing it is quite full
  • Ray M. Jul 13, 2010
    ummm...what brand and model? razors
  • 206 Answers
All you have to do is take out the cartridge and put it back in and restart the machine
Posted on Jul 13, 2010
Why does my kyocera 2026 display an error and says add toner even if I have already added toner?
because your dv unit is not agitating your toner these machines are notorious for this you can take out suspect color dv unit cover the toner hole shake the hell out of the unit smack the bottom a few times put it back in and if that works it will say adding toner it may overtone that color but running multiple copies will eventually clear the excess its best if you wrap the unit in a rag as well as cover the toner hole because toner will leak out when you shake it or replace that color dv unit but they are expensive if you don't know how to remove the dv unit try google or youtube try not to let anything come out when you shake it because there is developer as well as toner in there if you lose too much of that your unit will be worthless it wont ever be able to add enough toner to get add toner message to stop
Apr 08, 2017 | Kyocera 2026 Copier
Error message display (adding toner), but the catridge is full with toner.
cartage dispenser wheel might have broken,try with different cartage .
Feb 17, 2014 | Toshiba e-Studio 232 Black and White...
ADDED TONER STILL ERROR ADD TONER
You can drop the toner cover and cheat the door sensor and watch the toner bottle to see if it spins or not. If it doesnt spin- the end result is not good especially if you have a grinding noise. or just the toner bottle not spinning and it asks to replace toner. The back of the machine will have to come off. You will have to remove all the covers and finisher off the front. Then get to the toner add mechanism and take it out. The one gear will probably be sideways because- if the customer put the toner in wrong or maybe the wrong toner in- it will bind and bend that back shaft. thereby screwing it up. It takes a lot of time and parts. First thing you need to do though- is to see if the bottle is spinning or not
Jul 25, 2012 | Minolta bizhub 250 Black and White Copier
Screen is displaying Add toner. I have followed
please try to open the cover while the machine is on and close it back or remove the toner and putt it back sometimes the machine not register the new toner good, so you need to do this two or three times if this not help call a technician
Dec 23, 2009 | Ricoh Aficio 1013 All-In-One Laser Printer
How do I install the toner cartridge?
I reproduce below the content from Ricoh official website. The instructions to install toner cartridge are as follows:
Note: You can make about 50 copies even after the char_ric09.gif Add Toner indicator begins flashing, but replace toner early to prevent poor copy quality.
Please read the following warnings and notes before attempting to add toner.
WARNING
  • Do not incinerate used toner or toner containers. Tonerdust might ignite when exposed to an open flame. Dispose of used tonercontainers in accordance with local regulations.
  • Keep toner (used or unused) and toner containers out of reach of children.
  • Iftoner or used toner is inhaled, gargle with plenty of water and moveinto a fresh air environment. Consult a doctor if necessary.
  • If toner or used toner gets into your eyes, flush immediately with large amounts of water. Consult a doctor if necessary.
  • If toner or used toner is swallowed, dilute by drinking a large amount of water. Consult a doctor if necessary.
  • Avoidgetting toner on your clothes or skin when removing a paper jam orreplacing toner. If your skin comes into contact with toner, wash theaffected area thoroughly with soap and water.
  • Iftoner gets on your clothing, wash with cold water. Hot water will setthe toner into the fabric and may make removing the stain impossible.
To replace the toner, follow these steps:
  1. Keep the device switched on and only add toner when "Toner is Almost Empty" is displayed
  2. Open the Front Cover
  3. Lift the large green handle up to its full extent
  4. Press and hold down the green lever to the left of the green handle
  5. Use the green handle to pull out the Toner Tray slightly then release the green lever
  6. Pull out the Toner Tray to its full extent
  7. Push the neck of the Toner Bottle back towards the device until you can see the top of the bottle
  8. Lift out the Toner Bottle by the neck - being careful not to scatter loose toner
  9. Dispose of the Toner Bottle in accordance with your local environmental instructions
  10. Obtain a new Toner Bottle and shake it gently from side to side at least 5 times
  11. Remove and discard the black cap and place the Toner Bottle in the tray with the neck towards you
  12. Push the neck back into the black housing of the tray
  13. Push the whole assembly back into the device until it clicks into place
  14. Push the green handle down fully and close the Front Cover
  15. The device will perform a few seconds of internal checks before it is ready for use again
Important:
  • Fault may occur if you use toner other than the recommended type.
  • When adding toner, do not turn off the operation switch. If you do, settings will be lost.
  • Always add toner when the device instructs you.
  • When a message "Add toner." is shown on the display panel, replace the toner.
  • Store the toner bottles in a cool, dry place free from direct sunlight.
  • Store on a flat surface.
  • Do not repeatedly install and remove toner bottles. This will result in toner leakage.
  • Do not shake the removed toner bottle. Remaining toner might scatter.
Aug 17, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Jan 28, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Add toner message
have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Savin 9935DP Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
71 people viewed this question
k24674
