Question about Dishwashers
My fisher paykel DD603 fills with water at the start of the cycle and stops with the following error code and a beeping noise: - error U1 spanner symbol - crossed out faucet symbol. The water level is high enough that the spray arm is floating in the water. I am able to drain the water by entering the hardware diagnostics mode and running the motor in the drain direction. By removing the filter plate and examining the impellers I am not able to see visible damage. All filters are clean. The water pressure is normal. I opened the bottom draw and removed it from the rails and examined the flood switch sensor which appears to be dry. I cleaned and replaced all contacts in the flood switch. Is there anything else I can try? Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are spot on as error U1 indicates that the dishwasher has twice tried to fill with the required amount of water however, on both the try correct level was not detected by the fill system. As you have already checked the water inlet valve and also cleaned the flood switch, then check the drain hose for any blockages. Also check the labyrinth plate which is a stainless gauze plate located at the bottom of your dishwasher. If still the issue is not resolved then the water inlet valve should be replaced as I said earlier this error means water pressure issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 13, 2010
  • rjayasha Jul 13, 2010
    See my comments inline:
    > The dishwasher fills with a sufficient quantity of water
    > Drain hose is ok, since I am able to drain the dishwasher in the hardware diagnostics mode
    > Is this the filter plate? If so, the filter is clean
    > If the water level is sufficient why will it be a water valve issue?
    Thanks.
  • Rylee Smith
    Rylee Smith Jul 13, 2010
    Thanks for your reply. First thing I was just telling you what the error code means and yes if the water inlet valve is fine it should be replaced. Labyrinth plate is a stainless gauze plate located at the bottom of your dishwasher, dont think labyrinth means filter. If all of the above is fine then the flood switch should be replaced as its not telling the control that the water pressure is fine.
Dd603 stops mid cycle with no beeps or alarms
Please check if this happens with the short rinse cycle as well.
Also when the fast cycle stops, check if the water is cold at room temperature. Normally water temperature for wash cycles should be at leat 40deg C.
May 04, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My fisher and paykel washing machine is not starting a cycle as it is not getting any water. The pipes are turned on and is properly connected. It results in service light(spanner icon) flashing with a...
Hi just read your posting.Now when the machine beeps do any lights light up to indicate an error code?You have mentioned the spanner shows up but do any others light up as the machine is beeping?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel WA37T26G Top Load Washer
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
