Question about Sharp DVRW550U
Sharp dvrw550u error message e4-54037380. This unit has been recording DVD-RW with no problem and suddenly we are getting the above error message. Tried serveal different disc, both Maxell and TDK DVD-RW . When disc is inserted, screen shows loading and next is formating. It never seems to get thru the formating process when messge " recording error, can not record to this disc E4-54037380". Unplugged unit for approx. 5 minuites, plugged it back in and tried again. Same results.
SOURCE: disc error
I have this same problem so I called Sharp.  This model is  a little older.  When you buy the disks there is a number with an X after it.  If you buy the - R disk the number has to be 4X or less,  for the -RW it has to 2X or less.  Apparently they can still be bought at Office Depot or online.
Posted on Oct 28, 2007
SOURCE: Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
Posted on Dec 18, 2007
  • 4 Answers
SOURCE: recording error E4 54037380
This seems to be a common problem on all DVD players.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
DerStrom
  • 103 Answers
SOURCE: i need a manual Sharp DVRW550U DVD Recorder / VCR
I have three possibilities for you. One obvious answer would be that you are trying to record onto either a CD-R rather than a DVD-R, but I'm assuming that's not your problem. The second would be that you are trying to record onto a dvd that your recorder doesn't support (i.e. DVD-RW and your recorder only supports DVD-R). The final possibility is that the disc is a "dud." I have had this problem before and just had to try another disc. Good luck and let me know how it turns out, will you? Der Strom
Posted on Apr 02, 2010
SpideRaY
  • 687 Answers
SOURCE: Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Posted on Nov 08, 2010
Error Message: Cannot record in VR-mode?
To be able to help you, tell me these things: What type of disc are you using (-R,+R,-RW or +RW), was the disc previously used in another recorder or computer, are you attempting to record in VIDEO or VR mode and have you done any formatting to the disc?
Jul 17, 2014 | Toshiba Dr430ku Dvd Recorder - Black
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
I need a manual Sharp DVRW550U DVD Recorder / VCR Combo.. when i record into the dvd it say that i cannot recorde into this dvd i already try so many diferent one and it say the same thing.. when i think...
Apr 02, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Samsung DVD Recorder "copy protected" error
I had a similar problem... went to samsung.com and downloaded firmware update for unit and instructions.... updated firmware and unit is now able to copy my own tapes from vhs to dvd.
Be sure to read and following firmware update instructions carefully...
Feb 24, 2010 | Samsung DVD-VR357
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
DvD will not format new DVD RW
I get the same message. But to be honest I'm lucky if it gets to 20%. The unit is so tempermental it's ridiculous.
Aug 07, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Disc error
Aug 11, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Problem with samsung dvd player.....
what is the model number of your dvd player? i suggest try to use DVD-R types. and try resetting the unit if this will help.
May 29, 2006 | Samsung DVD-R130 DVD Recorder
Televison & Video Logo
149 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
