Have a Kenmore 90 Plus Series Gas Dryer that will not heat when turned on. The gas supply is connected and gas is available to the dryer. The drum does rotate when turned on but does not get hot. Is there a sensor that prevents the gas from comming on. Model number 110.78932792.
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
I have written a troubleshooting tutorial on how to fix a 90 series gas dryer that will not heat: http://www.johnfixesstuff.com/2015/05/how-to-fix-kenmore-90-series-gas-dryer-will-not-heat.html
