Question about Magellan RoadMate 300 GPS Receiver
My magellan roadmate 1700 will no longer make a sound - volume is ALL the way up and mute is off Any help is GREATLY appreciated.
5 Suggested Answers
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 24 Answers
SOURCE: how do I reset my magellan roadmate 760?
Your magellan roadmate 760 unit does not have any reset option.To over come the signal problem just follow the trobleshooting steps givven below .............
NOTE: If you are trying these steps from your vehicle, it is
Recommended to follow when the vehicle is in a stationary position.
Make sure that the device is exposed to the clear view of sky.
With the antenna pointing upwards, remove the antenna and then re-insert.
Swivel it up and down to make sure its securely placed.
wait for few mins and check the signal indicator.
Still not working,
  • Turn on the unit and select any user.
  • Make sure that the antenna is in the upright position and the unit has
    a direct line of sight with the sky.
  • Select 'Option' from the keypad.
  • Then select 'Configuration'.
  • Scroll down to select 'Diagnostics'.
  • Scroll down again to select 'Initialize GPS'.
  • At this point you would receive two options, 'Yes or No' - select 'YES'.
  • Now scroll down and select 'Set GPS Position'.
  • Enter your City, Street name and number at the corresponding
    prompts.
NOTE: The address that you are entering in the Set GPS Position should be the address at which you are at that point of time.
Posted on Feb 10, 2008
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: after dowloaldin and then uploading
tim if you havent already sent your unit into magellin i have a 5 min fix for you.
1) plug in your magellin
2) when the auto play option pops up on your computer, click open folder to view files
3) double click the app folder
4) find FirmwareReleaseVersion.dll and delete it.
now just simply unplug your roadmate 1700 reset it and plug it back in to your compter and re download the updates. you will start with version 2.77 then version 3.11 and it should work.
josh
Posted on Jan 26, 2011
My Magellan roadmate 1700 doesn't open completely ,how can I fix it?
I had to send my 1700 back, contact magellan & see what they say
May 15, 2014 | Magellan RoadMate 800 GPS Receiver
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
Can you download philippines map to madgellan roadmate 1700 gps?
Visit the website of Magellan for your country or their global site. Find the maps, pay for them and download to your computer. You will have access to the installation instructions. Usually you install some software by Magellan, you connect your device to your computer and the proprietary software will install them on the GPS.
Mar 18, 2014 | Magellan RoadMate GPS
Loading a philippines map
Mar 17, 2014 | Magellan Roadmate 2120T-LM GPS Vehicle...
I just bough a madgellan 1700 roadmate gps. i need to know if i can load it with philippines map?
Mar 17, 2014 | Magellan RoadMate 1700 GPS Navigator
My Magellan Roadmate app on my iphone no longer has a voice telling me to turn left, then turn right, everything else works.
In the magellan app, select the Menu button in the middle at the bottom:
select the configuration icon at the same position, represented by a wrench and a screw driver
select voice languages and choose your preferences of voice, you should hear an example of the voice.
if you dont, turn up the volume, switch the mute slider, or disable bluetooth if you have a bluetooth device in your vehicle that you have recently paired to.
Dec 17, 2010 | Cell Phones
Magellan Roadmate 1212
Instructions and POI software are on the CD that was packaged with your GPS.
Dec 26, 2008 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Magellan RoadMate 300 GPS Receiver Logo
258 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
