Question about HP Compaq nc6000 Notebook
Usb port My usb port does not work,I kindly request you to guide me how to fix it.
  • 1 more comment
  • alireza_zare Apr 20, 2008
  • RAFFat May 04, 2008
    after I had have fixed problem with my touch pad mouse, I have another with my USB! no problem has found. but there is no any devise could been recognised , like there is no any USB.IN MY NC6000.
  • SGNC6000 May 09, 2008
    Whenever a USB device is connected to the USB Port, USB port develops loose contacts i.e USB port reads and disconnects frequently
    Problem Solver:
  • 10 Answers
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Thanks Iqpal !! I've done all what you said but there is still the same problem.. no usb and no Blue tooth neither .. I will try to see what kind of fail it could be inside the case .. and I will let you know
Posted on May 28, 2008
  • 655 Answers
Zare,
what do you want to do?
Do you want to use any USB device and your system cause promlem for that device? OR
The system does not recognize any USB device connected to it.
If its create problem with any specific device then you might be to install deriver for that device.
If your system does not recognize any USB device like flash memory etc. and your system is XP/Vista then:
Goto device manager
Un-install USB drivers for USB controller
Restart your system.
Install USB drivers from Windows setup disk.
If any more question just..Ask me
Please post your feed-back in comment.
Thanks
Iqbal
Posted on Apr 20, 2008
I purchased usb hub 2.0 64bit, its only two ports work at the same time, i want to use its all ports it has also external power dc injector so kindly guide me how do i use external power to use all ports
Typically the external power source will be 5 volts and 1 or 2 amps. You will need to make sure that the connector has the correct polarity. I would contact the manufacturer for advice.
Jan 12, 2015 | Power Computers & Internet
WR 703N TP-Link Quick Installation Guide Router
It only has two ports. RJ45 for network and USB for an Air card. Use one or the other. The Micro USB is for power. That's it
It is designed with 3 kinds of power supply options:
1. Via external power adapter with Micro usb output plug
2. Via power adapter of cell-phones with micro usb output plug
3. Via USB connection with computer
Oct 08, 2012 | Computers & Internet
My usb ports are not charching my controllers and my logitech headset wont work in the ports
There is no need to have technical knowledge to do fix this problem.....Just get repair guide from internet and follow the steps in it and fix your problem by your own.......
Click here to download repair guide
Jan 04, 2011 | Sony Playstation 3 (PS3) Console
When I try to plug in my USB 2.0 Flash Drive into my Xbox 360, it will not work. Please Help!!
Microsoft xbox360 Generally generates this error if its main port gets problem.......
you can fix this problem easily .. with out Having much technical knowledge...... you can do this easily with the help of repair guide ....
Click Here to download repair guide
Dec 09, 2010 | Microsoft Xbox 360 Console
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
LAPTOP ACER TRAVELMATE NO USB PORTS WORKING
clarification request:
check the plug and play if working properly also check the usb port maybe lose usb port
May 27, 2008 | Acer TravelMate 2300 Notebook
USB ports not working DV 1000
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Dec 06, 2007 | HP Pavilion dv1000 Notebook
T-mobile mda usb port broken
try other USB ports on your comptuer and try it on another computer before trying to open it up
Nov 13, 2007 | T-Mobile MDA
HP Compaq nc6000 Notebook Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
