Question about IBM ThinkPad DVD_ROM Ultrabay (73p3270) Internal DVD Drive
Similar problem - DVD on Thinkpad T43 will not eject - despite numerous tries, including restart laptop and removing the drive. Help
xerick
  • 139 Answers
SOURCE: IBM Thinkpad T21 2647 8AU remove Administrative password
to remove the administrative password follow this link for all about removing admi password its free check it
http://www.kellys-korner-xp.com/win_xp_passwords.htm
then for bios password try to remove the cmos battry for while then put it back for some systems the password may not go off. in that case, the password is stored in a chip the 24co2 ic which i can not locate the actual position. thank u
n plz tell me the extend uv gone if this helps.
bye
Posted on May 27, 2008
SOURCE: how toremove ibm thinkpad t43 password
HI,
KINDLY SEND THE STEPS FOR REMOVE THE BIOS PASSWORD
REGARDS,
RAAJAA,
Posted on Dec 28, 2008
benwabnick
  • 2404 Answers
SOURCE: my ibm thinkpad t43 displayed a message "hard error d0014"
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Posted on Jun 04, 2009
  • 253 Answers
SOURCE: T43 speaker not work, use ear phone is ok, any
go into your laptop's Bios and check that the speaker are not muted in the Bios
Posted on Jun 25, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
Wireless and Bluetooth not working running on ubuntu
Instructions
Close any open programs and files. Click "Start," "Run."
Enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Open:" box.
If your IBM T43 is running Windows Vista or 7, enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Start Search" box.
http://www.thinkwiki.org/wiki/How_to_setup_Bluetooth
Press the "Enter" key on your computer's keyboard. The Wireless LAN setup wizard will appear.
Follow the onscreen prompts to complete the Wireless LAN installation. You will be prompted when the process is complete.
5
Click "Start," "Turn Off Computer," then "Restart" to restart your computer when the Wireless LAN setup process is complete.
Tips & Warnings
If you haven't already downloaded the Wireless LAN utility to your T43 laptop, click on the "Wireless & Networking Accessories - ThinkPad T43/p" link in the Resources section. Then click on the "ThinkPad 802.11abg wireless Lan Mini PCI Adapter II" link to download the Wireless LAN utility.
Jun 07, 2012 | IBM ThinkPad T43 Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
I AM A LAYMAN USING T43 IBM THINKPAD.CD/DVD DOES NOT WRITE BUT CAN RED.PL.ADVISE ( on the slot is written CD RW DVD ROM
If you are trying to write to a DVD, you should know that this drive does NOT record DVDs. It should record CDs with no problem. If you haven't changed the operating system, It should be a breese. Other wise, the drive could be bad.
Apr 07, 2011 | IBM ThinkPad T43 Notebook
It does not boot anyway on hdd or cd, i have ibm screen one time out of ten ; IBM T43 PENTIUM M 1.86GHZ/RAM 1Go/HDD 40.Go BIOS already updated with latest version from lenovo
restart the system and continue to press F2 ,so tht u can enter into the BIOS settings,change the boot option to cd/dvd...if still the problem persists clean your dvd case once or continue with another cd/dvd...
May 06, 2010 | IBM ThinkPad T43 Notebook
T43 is getting slow ,
scan your computer with good updated antivirus.
Remove unnecessary program also remove temporary files.
Delete allcookies temp intenet files ,prefetch files.
Go to start menu then run type in run "chkdsk /r "
then press "y" then restart it then it fix error on harddisk.
Jun 25, 2009 | IBM ThinkPad T43 Notebook
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
IBM T43 Screen Turns OFF After Removing Charger Cable
Sounds like a bad battery to me. If you have a DC voltmeter you can check the battery.
Feb 23, 2009 | IBM ThinkPad T43 Notebook
Changing dvd drives
Are you trying to remove the entire physical drive? If so there should be a small slide switch on the bottom of your machine to allow for easy acess. Try find that first, sliding it and gently pulling on DVD drive.
Dec 16, 2008 | IBM ThinkPad T43 Notebook
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad DVD_ROM Ultrabay (73p3270) Internal DVD Drive Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
