The ball on my 'mouse' seems to be skipping...can
The ball on the underside of my 'mouse' seems to be skipping/sticking...can I fix it or do I need to buy another one?
Mouse with its own mind
If the mouse has a ball, it probably needs cleaned along with the wheels inside behind the ball. Always do all maintanance with the mouse unplugged from the computer. You can see them when you take the ball out. Typicaly, you twist the cap holding the ball in and it just falls out. At this point, you can clean the ball with a mild cleaner and the wheels inside the mouse with a pencil eraser, pocket knife or a Q-tip with rubbing alcohol.
If it's an optical mouse (red or blue laser under the mouse) simply clean where the laser light is. If this does not work, then plug the mouse into another USB port. If that does not work, then restart the computer properly (not hard or soft reset). That should fix it. If not then the mouse probably is bad.
Mar 14, 2015 | Computers & Internet
My mouse keeps sticking
is it a male or female mouse? "does it have a light or a ball"
To fix a ball type mouse
Remove the ball and clean the rollers with a pencil eraser
The light type mouse sticking is usually caused due to high CPU usage. To check this right click on the task bar and click start task manager. Then click performance. if your CPU is at 100% then that is why it is sticking.
I would start with a malware scan
Mar 02, 2015 | Microsoft Windows Vista Home Premium with...
Can I fix the roller in my wireless mouse?
Open the mouse. (Slide the panel on the bottom that surrounds the ball, and pull the ball out. Clean the ball and the rollers inside the mouse with rubbing alcohol. Remove all debris, hair, lint, etc.
Voila!
Sep 26, 2014 | Computers & Internet
I am using Windows Vista. My pointer keeps shaking. How can I fix this?
unplug your mouse... & see if it is still shaking...
if not then its time to replace the mouse...
Jun 16, 2010 | Wacom Graphire4 4x5
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
My mouse pad will not move my cursor on my computer
If your mouse is the older ball type hold the mouse level about 12 inches off the pad and move the ball on the underside of the mouse with your finger. If the cursor moves you may need to simply clean any dust from inside the device and clean the ball. Open the open to release the ball. Theres a round plate on the underside around the ball. Turn it to the open position a remove the ball. Clean any dust from inside with canned air or a soft brush. Clean the ball with a small amount of alcohol and let dry completely. Replace ball and plate and you should be ready to go.
If you have an infrared mouse, your mousepad may be too glossy. Dry a pad with a dull finish.
Jan 18, 2010 | Computers & Internet
Mouse somtimes sticks
unscrew the ring that holds the ball in place and remove the ball. clean out any lint, or dust, etc on the ball and inside the mouse where the ball sits and rides. once it is clean put the ball back in and replace the ring. that should solve your sticky mouse problem
Oct 25, 2009 | Dell U0636 Mouse
My mouse seems to slide over the pad it is hard to get the arrow where i want it
If it is an optical Mouse it will need to be recalibrated. You cna do this in
Control Panel/ Mouse
Then Click on the Pointer Settings Tab and adjust the speed at which your mouse will move.
If is is a old ball mouse then you will need to start by removing the gromet that holds the ball in place on the underside of the mouse by turning it coounter clockwise.
Then remove the ball you will see some rollers inside and you will need a pair of tweesers to remove any accumulated debris on the rollers. then follow the instructions as above to see if that makes a difference.
Sep 21, 2009 | Dell U0636 Mouse
We have a wireless keyboard and mouse and it seems that something between them and the computer is slow or off. we type and only a few letters appear..the mouse seems to be ok just kinda slow ofrom when...
Most likely you need to re-sync the device
  1. Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers. Use the following steps to resync the devices:
    NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
    1. With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
      NOTE: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a connect button - skip this step. Figure 4: An example of a receiver c01065862.jpg 1 - Connect button and LED activity light Figure 5: Another example of a receiver c00526313.jpg 1 - Connect button 2 - Num Lock LED 3 - Alpha Lock LED 4 - Scroll Lock LED 5 - Activity LED
    2. Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position.
      NOTE: If problems persist after resetting AND there is another wireless keyboard or mouse near, use these steps again, holding down the keyboard or mouse button for ten seconds. Doing so may give the keyboard or mouse a new ID number in case the other keyboard or mouse was using the same number.
    3. Press the Connect button on the receiver again until the activity light flashes.
    4. Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position.
  2. If your mouse and keyboard have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Hope this helps!! Good luck!!
Sep 17, 2009 | HP Wireless Optical Mouse
Mouse sticking
Probably needs to be cleaned. Turn it upside down and take the bottom off that is holding the ball. Use a toothpick to pick the gunk out and then wipe the ball off with a damp washcloth. Let it air dry or wipe with a clean lint-gree cloth. Should fix it up. mine does that all the time.
Feb 02, 2009 | Dell U0636 Mouse
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
