Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 Error 07,010.43:14599
Xerox Phaser 8560 Ошибка 07,010.43:14599 var gtbTranslateOnElementLoaded;(function(){var lib = null;var checkReadyCount = 0;function sendMessage(message, attrs) { var data = document.getElementById("gtbTranslateElementCode"); for (var p in attrs) { data.removeAttribute(p); } for (var p in attrs) { if ("undefined" != typeof attrs[p]) { data.setAttribute(p, attrs[p]); } } var evt = document.createEvent("Events"); evt.initEvent(message, true, false); document.dispatchEvent(evt);}function checkLibReady (){ var ready = lib.isAvailable(); if (ready) { sendMessage("gtbTranslateLibReady", {"gtbTranslateError" : false}); return; } if (checkReadyCount++ > 5) { sendMessage("gtbTranslateLibReady", {"gtbTranslateError" : true}); return; } setTimeout(checkLibReady, 100);}gtbTranslateOnElementLoaded = function () { lib = google.translate.TranslateService({}); sendMessage("{EVT_LOADED}", {}, []); var data = document.getElementById("gtbTranslateElementCode"); data.addEventListener("gtbTranslate", onTranslateRequest, true); data.addEventListener("gtbTranslateCheckReady", onCheckReady, true); data.addEventListener("gtbTranslateRevert", onRevert, true); checkLibReady();};function onCheckReady() { var ready = lib.isAvailable(); sendMessage("gtbTranslateLibReady", {"gtbTranslateError" : !ready});}function onTranslateRequest() { var data = document.getElementById("gtbTranslateElementCode"); var orig = data.getAttribute("gtbOriginalLang"); var target = data.getAttribute("gtbTargetLang"); lib.translatePage(orig, target, onProgress);}function onProgress(progress, opt_finished, opt_error) { sendMessage("gtbTranslateOnProgress", {"gtbTranslateProgress" : progress, "gtbTranslateFinished" : opt_finished, "gtbTranslateError" : opt_error});}function onRevert() { lib.restore();}})(); (function(){var d=window,e=document;function f(b){var a=e.getElementsByTagName("head")[0];a||(a=e.body.parentNode.appendChild(e.createElement("head")));a.appendChild(b)}function _loadJs(b){var a=e.createElement("script");a.type="text/javascript";a.charset="UTF-8";a.src=b;f(a)}function _loadCss(b){var a=e.createElement("link");a.type="text/css";a.rel="stylesheet";a.charset="UTF-8";a.href=b;f(a)}function _isNS(b){b=b.split(".");for(var a=d,c=0;c
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
  • 2072 Answers
SOURCE: Error Code 09,038.46:1529
One of your ink sticks is stuck and not loading properly. It is not advancing down in the ink loader.
Look for a twisted block, cracked or just stuck not sliding down.
If you need to remove them take a screw, like a dry wall screw and twist it into the block then slide it out or down.
Posted on Jul 01, 2009
  • 17 Answers
SOURCE: xerox phaser 8560 close control panel error
Bad control panel. Xerox will replace for free (800 635 8100) call and ***** to get it for free (They had a "LOT" of defective panels)
User installable.
Posted on Aug 21, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
Error code 07,015,48:94562
That error signifies the head tilt restraint is out of place. There is a kit that solves this error, the part number is 8560-Z2. http://www.iteminconline.com/itemdesc.asp?ic=8560-Z2&eq=&Tp=
Aug 27, 2014 | Xerox Phaser 8560MFP Laser Printer
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Jul 26, 2010 | Xerox Phaser 8560DN Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
