Question about Briggs & Stratton 100A Transfer Switch with Air Conditioning Control Module
I am a journeyman electrician. I just installed a 100 amp briggs and stratton transfer switch. Everything works fine (when power from utility is shut off, the generator starts, when power is turned on, the generator turns off) except: the power transfer from utility to standby power does not occur.
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly a 35 + year electrician. Is this an automatic and GFI transfger switch?
Connections should be
N1 and N2 to Utility main
T1 and T2 to house load
E1 and E2 from Gen supply
Neutral lead must connect to all of the following in one circuit
1. the generator neutral
2. Main switch board neutral
3. the transfer switch neutral.
If this is a GFIC transfer switch you may have to disconnect the neutral from the generator. Local electrical codes are very restrictive and in many states disconnecting this neutral lead will result in your no longer being in compliance with existing code.
In the majority of transfer switches there is a "remote" and "no remote" setting that is explained in the transfer switch manual. It is related to terminals 178 and 183 of the transfer switch. You may have connected yours up in the "no remote" position.
Thanks for using FixYa.
Kelly
Posted on Jul 13, 2010
  • Kelly
    Kelly Jul 15, 2010
    One other comment is that if you have the sense line on the house load T1 and T2 Vs utility supply N1 and N2 it will perform exactly as you stated. It will work when the utility power goes off but will not switch from gen / standby power when the utility main power returns. If you routed T1 and T2 close to the N1 and N2 line sensor it can still via inductance cause the same problem even if you have it connected correctly. Make sure T1 and T2 are no where near the line sensor.
    Kelly
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Just finished installing a 20 KW Generac generator (fueled with natural gas). The included transfer switch will not automatically transfer to the generator, but transfers back to the utility without...
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
Mar 09, 2011 | Generac Guardian RTSE200A3 200 Amp...
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
Does 200 amp supply need 200 amp transfer switch
Yes this is true, any means of disconnect has to have the amperage rating of the supply otherwise a fire can occur from overheating of wires and connections.
Jun 24, 2010 | Briggs & Stratton 100 Amp Transfer Switch...
Wheres the fuel switch on a 2003 model seat ibiza
hi
follow the fuel line from the gas tank to the carburator
regards savumihai71
Dec 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
Installed a 20K gen to run 5 ton a/c and a couple of small appliances and well pump, After electrician left a circuit board burnt up in the a/c. Any ideas?
A couple of things, there could have been a problem with the connection (transfer switch) or if your underpowering the unit (C air takes a lot of juice to run) you can also fry the circuits as well. Too little power can do just as much damage as too much power. make sure the load of the Gen is sufficient to run all your devices based on whats running all at a time. if your Gen is only ment to run 60% of the house and you have 80% of it running you ca do damage to your electrics as well as the generator. have your electrician come back out and inspect/account for his work.
Aug 15, 2009 | Briggs & Stratton 15,000 Watt Home Standby...
I'm wiring a briggs and stratton 1918 automatic transfer switch. how do i wire the chosen circuits to be powered? would they be wired exactly as if they were at the main panel?
With any transfer switch, automatic or otherwise, there are three (3) connections:
1. The normal feed (from your local utility)
2. Emergency feed (from your generator)
3. The load (your power panel or other electrical loads)
The transfer switch should be marked "N" for normal, "E" for emergency, and "L" for load
If you want individual circuits, then you will need a second power panel to separate the circuits.
This can be tricky, and if you are not familiar with transfer switches or emergency power, it's best left to a licensed electrician.
Jun 21, 2009 | Briggs & Stratton 50-Amp Automatic...
Briggs & Stratton 100A Transfer Switch with Air Conditioning Control Module Logo
51 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
rlev_7
Level 1 Expert
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
