Question about Sony Playstation 3 (PS3) Console
My ps3 will not display though the hdmi port have tried the reset several times and still does not work, please help
  • 206 Answers
Try replacing the hdmi cord
Posted on Jul 13, 2010
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
No signal through hdmi ports
Check the hdmi cables be sure their in proper working condition, wiggle the cables around see if picture comes up. If not and the cables are good then the hdmi processor on the main board of your TV is defective. Alot of times hdmi ports tend to burn so see if you smell a burnt smell near or around the hdmi ports. but before you do anything be sure sure your TV settings are correct for hdmi....
Oct 18, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Im trying to connect my playstation 3 up via hdmi, when setting up it says it detects the hdmi cord do you want to use it and i say yes then the screen goes black for 30 seconds, i have tried switching the...
Have you tried using another HDMI device with any success on the same port? It would be good trying something else on your TV just to make sure the TV isn't the problem.
Also, try turning your PS3 off, then, while it is off, hold the power button down for about 5 seconds. The system will beep, and it will reset the video settings. Try your HDMI setting one more time, but this time set it to 720 p to make sure the resolution isn't too high for your television.
If none of this works, you could possibly have a faulty HDMI port on your PS3. I've seen it happen before.
Feb 01, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Ps3 no display - reset doesn't work?
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem.
Mar 21, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
It wont run through HDMI
Follow the guy aboves solution to reset your Ps3 to 480i. Turn the power to the system off from the switch on the back and then when you flip it back have the power button held down on the front of the system. This only resets the picture doesn't change anything else or erase any games, I had to do it and it works!!
Oct 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
