Question about Danby DDR586R Dehumidifier
Our Danby DDR586R dehumidifier is leaking from the tray above the water tank onto the floor. My husband cleaned out some black gunk he found in the tray's drain opening, but it still leaks.
  • 12 Answers
SOURCE: My Danby DDR586R dehumidifier shouts hot air
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
Posted on May 22, 2009
  • 117 Answers
SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Posted on Jan 05, 2010
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
  • 9 Answers
SOURCE: danby dehumidifiers
Try manually work the float and switch the float controls to make sure it is not hung up. You may need a new switch if that does not work.
Posted on Mar 24, 2010
SOURCE: DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Posted on Jul 18, 2010
  • 4736 Answers
SOURCE: My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
Posted on Mar 23, 2011
Danby Dehumidifier DDR7009REE leaking water, bucket not full
The unit may need cleaning. You can contact Danby customer service (1-800-263-2629) to get in contact with a technician.
There may be something clogging the passage to the bucket and the water is finding the path of least resistance.
As well, it is important to remember to clean the filter once a month.
May 14, 2012 | Danby DDR5009EE Dehumidifier
Hello i have a dehumidifier Danby DDR586R water runs out of the bottom of unit
is the condensate resovoir in place correctly or full? take it out and put it back in.
May 10, 2012 | Danby Dehumidifiers
Danby 25pt dehumidifier not collecting water, fan is working can hear the compressor kicking in, is almost 5 years old though, is it time for a new one?
Christina, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this will help you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 18, 2011 | Danby DDR586R Dehumidifier
Dehumidifier not filling with water
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If it's a manually controlled
unit, set the knob to maximum.
problem.
I hope this helps you to troubleshoot & solve the problem.
Jul 18, 2011 | Danby DDR586R Dehumidifier
The dehumidifier is not putting out any water. The fan is working. There is a lot of humidity but nothing is happening int he bucket thanks
Anya, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
problem.
Hope this helps you to troubleshoot the above and solve the problem. Please let me know. Thanks.
Jul 12, 2011 | Danby DDR586R Dehumidifier
Hello, I have a Danby DDR586R dehumidifier. Please help me troubleshoot the problem that it is not working. I turn it on and have selected different modes but there is no water going into it. Thank...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 08, 2011 | Danby DDR586R Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Jun 24, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Danby DDR586R Dehumidifier Logo
168 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
