Question about Sharp AL 1631 Copier
I get a black line through my copy when using the multi feeder. I've cleaned the transfer cartridge 10+ times as directed without success. This line does not appear when using the platten only with the multi-feeder.
  • 1,110 Answers
Clean the ADF Scanner glass. This is the small strip of glass that is separate from the platen glass. Right next to it. This glass is only used when the ADF (multi feeder) is used. All it takes is a small speck of something stuck to this glass to give you a line down the page as your documents are passed over the glass when copied. Anything stuck to the glass is therefor read as a solid line.
Clean this glass with some glass cleaner and a soft cloth and you should be fine.
Thank You for using Fixya.
Posted on Jul 13, 2010
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
Aug 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
I am getting a very precise, dark line down the middle of anything scanned - fax or feeder-copies. Cleaned all available areas & changed toner cartridge without success.
if you have already cleaned all the areas in scanner, then the reason should be an error in your scanner interface cable. This is the flat, grey cable which is connected to scanner lamp. Try to disconnect it and connect it again. When you use your Canon just for printing, there should be no dark lines.
Also maybe you scanner lamp has a problem. These things you can't repair.
Good luck
pifonski
Feb 20, 2011 | Canon LaserBase MF5750 All-In-One Printer
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black lines when using copier
Lift up the document feeder and look for wite-out on the small glass.
If there is a sliding blue tab on the toner cartridge, move it back and forth 10 times. (cleans the charge wire)
Physically look at he drum, it should have no toner on it.
Sep 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Copy problems
Hi , This is a genral problem while copying from Feeder as the feeder might be dirty so cleaning the feeder will resolve the problem.. You can go through the below document with the instructions and graphical representation of cleaning the Feeder.. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&cc=us&lc=en&dlc=en&product=391194&dlc=en&lang=en Just click on the link to open the webpage and follow the steps.. Try to clean the fedder twice or thrice if the issue still presists.. Wish u success... Regards, Barret.
Oct 02, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Sharp AL 1631 Copier Logo
202 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
