Question about Samsung Refrigerators
My 2-year old Samsung side-by-side refrigerator RF-26V accumulates water standing under the two lower drawers in the refrig section. The water then leaks out somehow and onto the floor in front of the unit. There is a part of the refrigerator in the back that is stained brown on the rear left wall of the compartment - likely contributing. Thoughts?
  • vagentlemanj Jul 13, 2010
    It seems like an easier fix than I would have guessed, and it makes sense, but I have not yet been able to fix it because of not being able to remove the cover to the unit.
    OK - will do ... thanks for the clarification. That is the pipe that runs up the back - and I disconnect at the top and then see if I can push a wire forward and down into the refrigerator compartment to unblock - right?
  • 22,326 Answers
No at the back of the fridge inside is a drain hole that leads the water onto teh top of the motor in a bath thing so the water is evaporated by the heat of the motor ,this outlet is blocked somehwere ,clear it out and you will not get any more problems till it gets dirty and blocked again,anything could be blocking it from a dust and muck to a dead cochroach
Posted on Jul 13, 2010
    That makes sense.... I just tried to remove the long, vertical cover inside on the back wall - the staining is seeping out from the bottom of it - but after removing the only 4 screws visible, it would not budge. Any thoughts as to how to get into that compartment to find the stoppage?
    Thanks,
    Jon
  • Colin Stickland
    Colin Stickland Jul 13, 2010
    not really as never seen this model as such but have a look at the motor round the back and i wouldnt mind betting the blockage is their on the end of the pipe where it empties into the recepticle ,big words today ,hmm the plastic bath thing on top of the compressor .If need be use a length of fence wire or a plastic wire feed thingy that you pull wires through with and see if you can get it all the way through.dont worry about cockroaches they get every where regardless ,we have a wasp here that makes a nest in places like this and then interns a live spider that it lays its eggs onto so the lavea eat the spider ,they cause no end of problems with the parked cars and then the AC leaks inside the motor .had one make a nest in the outlet of my outboat boat engine ,good job i always check water flow before i un moor it
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Why is my refrigerator producing an oder?
CONTENTS OR OLD FOOD UNDER BOTTOM DRAWERS OR OUT OF SIGHT IF SMELL INSIDE REFRIG.
Feb 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Jun 30, 2009 | Kenmore Refrigerators
Samsung RS2545 side by side refrig, the drawers in the refrig seems to have ice built up behind wall that is pushing the drawers out too far.
Because your refrigerator has dual evaporators you can start by defrosting. Yes the old time defrost. Once the ice is gone on the refrigerator side lets try slowly adjusting the fresh food sections to temps acceptable to the foods safe temperatures. I will send you the service manual but if a sensor has malfunctioned you may need to call or order parts. Sea Breeze
Jun 27, 2009 | Samsung Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Maytab MTB2155BR Refrig that's leaking water. The freezer is on top and the water seems to be accumulating in the refrig section under the criper draws. Somehow it then leaks onto the floor. ...
Have you any tears in door gasket or do you see any way air is getting in the door through the door seal gasket?Is your temperature holding .Or have you had to turn it up??
Jun 18, 2008 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
