Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman 917.270680. When i attempt to shift it into gear, it will not move - starts fine just won't shift into gear. what part could be missing to cause this?
4 Suggested Answers
  • 86 Answers
SOURCE: Craftsman lt1000 with manual transmission,
The detent Shaft inside transmission lost its ball and spring if its working outside transmission,could be other damage .
Posted on May 09, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
suzukiracing
  • 200 Answers
SOURCE: Craftsman 42 '' 19.5hp lawn tractor gear shift
the belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Testimonial: "Good to know. Thanks for the quick reply."
2004 Jeep Liberty, gear shift stuck in park. button won't go in
The first thing to do is check the brake lights, it they are not working the park lock system will not release the shifter.
May 17, 2013 | 2004 Jeep Liberty
2004 Lincoln aviator goes into gear but won't move
bad transmission maybe. Try going into a lower gear (2 or 1) and giving it a little gas and holding it there. (about 2500 rpm) Hold it there for about 30 seconds.
If it still doesnt move, look under at the side of the transmission where the shifter cable connects and make sure it is moving.
Make sure the brake is on and the wheels are blocked and have a friend shift it back and forth while you look.
Sometimes, the connection pin comes out and you wont shift. .
If it does move right away, head to the transmission shop.
Dec 30, 2012 | 2004 Lincoln Aviator
Saturn will not shift into gear
If the shifter won't move, you could have a problem with the brake switch or the solenoid that unlocks the shifter.
Jul 08, 2012 | Saturn LS Cars & Trucks
Why won't the gear shift move to drive
you need to check and see if your brake lights are working, the same switch operates the shift interlock solenoid.
Mar 05, 2012 | Cars & Trucks
2000 Ford Tarus- Took off from stop sign just fine then car wouldn't go faster. As I pushed the gas, the car reved but wouldn't go. Pulled over and shut car off. Started car again and tried...
I would guess that something inside of the transmission has failed and there is no longer a mechanical connection between the motor and the drive axles regardless of what gear you attempt to move in.[sheared splines, broken planetary, etc.] Often when this happens you won't hear any kind of noise because of the failed parts being inside the transmission case...instead the car just won't go anymore. You could have a CV drive axle joint that has failed but generally they will make some noticable rattling or grinding noise as they churn away when you try to go forward or reverse. If something has failed inside of the transmission then the transmission will need to be removed and repaired. It if is just a drive axle joint that has failed then that can be replaced without doing anything to the transmission. Hope this helps and good luck!
Aug 31, 2011 | 2000 Ford Taurus
Why wont car shift into gear
Hello and welcome to FixYa!
You may want to start adjusting the brake pedals. If it detects that you are not stepping on the brake then it won't shift into gear.
If the gear is moving but won't shift gears while running then you may want to start on replacing the transmission fluid. It can be burnt that's why it's not operating properly.
Hope this helps and thank you for using FixYa! Have a good one!
Aug 14, 2011 | 1997 Ford Escort
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
112 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
