Question about AO Smith Three Phase Swimming Pool Pump Motor Ao Smith
Diagram of house water pump motor - AO Smith Three Phase Swimming Pool Pump Motor Ao Smith
  • John Prohaska
    John Prohaska Jul 13, 2010
    What brand and model number are on the motor?
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have an air leak in intake line
Question:
What do I do if my pool/spa pump is loosing suction or prime?
Answer: by Osko Pool n Spa Pool Pump Losing Suction or Prime If your Swimming Pools Filter system looses Prime, it is caused by one of the following conditions.
Note: The lost of suction/prime is caused a leak which in turn sucks air into the system. The lost of suction/prime will be anywhere from the Main Pool Skimmer(s) to the Pool Pump. It will NOT be from the Pool Pump to the Pools Main Return(s).
1) First make sure that your water level is high enough so that the skimmer is not sucking air.
2) Check the Pump Pot Housing Lid Seal and be certain that its completely sealing and is not
Sucking air into the system. Check the lid for cracks. If either condition is true, replace the Pump Pot Lid Seal and/or entire lid
3) Check all fittings, clamps and hoses from the pools skimmer to the Pools Pump Pot Housing for wear, tightness and leaks.
4) Check Pool Pump Pot Housing for cracks.
If everything aforementioned in good working order, the next thing to check is the Pump Pot Housing Main Seal and the Pumps Impeller and finally the pump.
5) While the Pool Pump Motor is running, carefully inspect the area where the Pump Pot Housing attaches to the Pump Motor. See if there is any water leaking. Next, spray the area with water and see if the water is sucked into the Housing. If so, your Main Seal is damaged.
6) Disassemble the front half of the Pump Pot Housing from the back half and inspect the Pump Motor Impeller. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged.
7) Re-inspect the Pump Pot Housing Main Seal by standing the partially disassembled upright, with the Pump Motor towards the ground. Pour water over the impeller and into the cavity. See if the water leaks thru to the outside of the Pump Pot Housing. If so, your Main Seal is damaged.
8) Remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged.
If everything seems to be in good working order, then you need a new pump... not just replacement parts
For more FREE DIY Faqs, go to:http://www.oskopoolnspa.com/index.php?main_page=faqs_all
Aug 18, 2013 | Hayward SAND FILTER, PRO SERIES
C48k2n143b1
possible leak from pump motor and pump housing its losing prime in basket less hassle to replace whole pump if leaking its ruining bearings in motor
Feb 15, 2018 | Pool & Spa
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
I have a stackable unit model numberltf2140fs2 it will not drain and go into spin cycle is there a strainer that needs cleaning how do iget to it
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Unfortunately, on this model, it's in a horrible place!
Rather than try to describe it, if you go to the Sears Parts direct site and look at the diagram for the motor and tub at this web address:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-Parts/Model-LTF2140FS2/1428/0153200/R0906023/00003
You will see a diagram of the drum and associated parts. You can zoom in on the diagram. In the bottom right section of the diagram, you will see part number 41, the filter housing ad part number 40, the filter its self. You will need to:
Remove the clip (No. 48) that holds the housing to the empty pump
Remove the clip (also No.48) that holds the air chamber to the housing
Remove the clip (No. 42) that holds the housing to the drum
You should now be able to remove the filter housing and filter. Strip and clean it before reassembly.
If the above doesn't get you where you need to be, please come back to me with a comment and I will provide further assistance
Aug 15, 2011 | Frigidaire Washing Machines
Hook up power from two 110 volts pumps from pool
I would run a feeder from the main breaker panel to a small breaker box near the pool pumps, so you have a disconnect near their location. Look at the drawing and see if you have any questions .. What is the amperage reading on the name plate label of each pump motor??
May 09, 2010 | Intex Automatic Salt Water System for ...
I have a Jacuzzi Jet Pump Model 7C-S/B. Not Working
Check the breaker that supplies power to the unit. If it is in tripped position, check if the motor is grounded ( continuity between terminals and motor body), check for shorted windings (infinity resistance value between the winding phases), and finally check if the pump is stuck up due to debris or defective motor or pump bearings.
Jun 08, 2009 | Plumbing
Automobile water pump
If it is a 3.1L the water pump when looking at the front of the motor is the top right pulley
Dec 11, 2008 | 1998 Chevrolet Monte Carlo
AO Smith Three Phase Swimming Pool Pump Motor Ao Smith Logo
90 people viewed this question
Top AO Smith Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an AO Smith Garden Expert? Answer questions, earn points and help others
