Question about Yard Machines Garden
Starter motor can't turn engine through compression stroke
MTD yard machine ride -on mower . 18.5 hp/42 inch Briggs & straton motor : ''Starter motor ( new ) can not turn the piston through the compression stroke . Even when I connect jumper cables directly to the starter motor terminals. Valves are opening and closing in correct stroke . Spark plug new , gets wet from fuel . Removed flywheel , all timming magnets good . Replaced flywheel in correct place as shaft has a key.
Initially the mower started and ran ,but I removed the brake for the blades (worn ) and ran the machine. When switched off the key the engine would backfire as the momentum of the blades still turned the engine.
  • Yard Machines Master
  • 1,004 Answers
Valves are out of adjustment. reset them and it will do fine.
Posted on Apr 08, 2017
SOURCE: Stalling Briggs & Stratton engine
Try taking the air filter off ,start the motor and try it. If this works replace air cleaner element
Posted on Oct 05, 2008
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
lester482529
  • 226 Answers
SOURCE: lt1000 17 hp . problem: starter will not turn
sounds like you have a ignition switch problem.same happened to me had to replace the switch.hope this help's.
Posted on Jul 11, 2009
lester482529
  • 226 Answers
SOURCE: MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Posted on Jul 16, 2009
nova2nv
  • 197 Answers
SOURCE: I have a briggs and strattan 18 horsepower engine
Set intake valves @ .004 and exhuats @ .006 with piston a 1/4 inch downstroke from TDC.It sounds like the ACR {automatic compression release}is not working do to valves having to much lash.
Posted on Nov 18, 2009
Manual for a briggs and straton riding lawnmower model #13ac762f755
Do you need the manual for the machine or for the engine? Your model number comes back to a MTD Yard Man mower.
You can go to Briggs' website after you get the serial and model of the engine, for a manual on the engine.
If you need particulars for the mower - follow the link. Yard Man Riding Mower 13AC762F755
Apr 14, 2017 | Briggs Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Remove starter motor briggs and stratton lawn tractor
My briggs 16.5 moptor wont turn over. It comes up on compression and stops. I have tried to jump it but the cables get really hot. Is my problem in the starter motor?
May 30, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
The starter will not crank over the compression stroke
You needv to check whatever the tractor uses for a decompresser,whether it be a lobe on the cam or the camshaft it's self.Sounds like it's not decommpressing during crank.You may need to just set the valves.
Oct 23, 2009 | Garden
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
5,195 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Morne Olivier
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
