Question about Frigidaire 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Freezer is cold but not freezing, refrigerator is not cold
Frost is building in back of freezer. Cleaned all the stuff under the toe plate and whole bottom.Can hear it running but feel no air coming from vents in back.
    President:
  • 2,468 Answers
Your defroster heating element behind the frosted panel is either open(bad) or the defrost heater control in the refrigerator compartment is defective
Posted on Jul 13, 2010
My Proline freezer has the warning on and won't get cold
if it is a frost free type it could be froze up.look for frost on the bottom back inside wall of the freezer,if you find frost there one of three things have failed,the defrost timer,the defrost heater or the defrost t-stat.if this is the case you will need to call your repair service to check it for you.too much electronics on all this stuff today i think.if on frost,check the cond. coil be hind the toe plate under the doors.this needs to be cleaned every 3 or 4 months.hope this helps.
Apr 16, 2014 | Refrigerators
Frost build up in freezer
You need a new bimetal fuse for your defrost cycle in your freezer.
Feb 28, 2014 | Hotpoint HSS25GFP Side by Side...
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
I have ice building up under the basket. It is
I would check your door seals to make sure they are doing there job. If warm moist air gets into an area of cold this will happen. You may need to get new seals for your freezer door.
Oct 07, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Jun 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cold enough
check freezer for frost build up on back wall and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 03, 2007 | Danby (DAR604BLS) Refrigerator
Frigidaire 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
144 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
