Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
How do i partion my segate hard disk, it is 5oo GB
Hard disk partition
  • Doug Olmstead
    Doug Olmstead Jul 13, 2010
    what is your question ( do you want to know how to partition?)
    Novelist:
  • 87 Answers
In order to partition a drive, you must use the partition manager. There is a command-line version of this application that is more consistent between the different Windows OS's so I'll instruct you in that.
First we need to be sure we are partitioning the correct drive. Open up My Computer and write down what drive letter your seagate external drive is (i.e. G).
Now let's start up disk partition manager. click on the Start button, and then click on "Run" type in "diskpart" (without the quotation marks) and press enter. This will open up a command prompt window with the heading "Microsoft DiskPart...".
Type in the following command: "list disk".
This will bring up a list of all of your disks currently recognized by the computer. Be sure the drive letter you wrote down earlier is on this list, also write down the drive number corresponding to your seagate external at this time. now go ahead and select this volume by typing "volume __" where __ corresponds to the drive letter of your seagate drive.
Now that we have everything set up we will create the partition.
type "create partition [size=_]" where _ is the size of the partition you want to add, in megabytes (MB).
If you encounter any trouble or want something more than a simple partition see the full instruction to use the diskpart utility here:
http://technet.microsoft.com/en-us/library/cc766465%28WS.10%29.aspx
Best of luck! and please rate my response
Posted on Jul 16, 2010
My hard drive capacity is 250 gb it is in a sigle local disk c: i want to make partion. what can i do to make partion ????
hi; you can try partition softwares, many software are avalailable in the internet.
search and download software with a free full trial. but i recommend
paragon partition manager.
its more stable and your data is safe when you partition your hard drive
or if you want to reformat your hard disk you can partition it by windows 7 and windows xp installer
if you read the intallation procedure theres an option of creating partitions
if somethings not clear just comment and i give some answer.
thanks....
Aug 28, 2011 | Computers & Internet
I am using segate u series ST340810 hard disk. when I am formatting this hard disk this hard disk does not shows partition to format and shows messege of disk cannot access what should I do?
Hello Ravindr,
After connecting the Segate Hard Drive in your computer go to Control Panel. In Control Panel you will the option Administrative Tool. In Administrative Tool open the Computer Management and you will find the number of attached Hard Drive and the Partitions they have. If the Hard Drive you have attached is not showing the partition then there may some physical damage with the Hard Drive media. Please get your Hard Drive checked by Segate professionals and then replace the Hard Drive with new one.
Jun 03, 2011 | Seagate U Series (ST340810) 40.02 GB Hard...
My Segate hard disk(barcuda) is 160GB but it shows only 40GB
Try to format the total hard disk deleting all partition and install again
Aug 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drive Capacity Stuck at 33.8 GB
You are probably using FAT32 for your partition on your drive: the limit for FAT32 is 32GB. Alternatively, you are using NTFS but your partition has been limited to that particular size.
You could you a Disk partition manager to change the format of your partition to NTFS or if you are already using this format extend the partion size to your requirements.
A safer alternative, if your current partition is set smaller than your drive size is to create additional primary or secondary partitions to fully utilize the available capacity: you could use (with great caution and only if you are experience) standard Windows Control Panel -> Systems and Security -> Admistrative Tools -> Computer management -> Disk management
Dec 24, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Hard disk partitions
If you are comfortable in booting the system in dos mode and running dos commands, The hard disk can formated through it. If not then you can download a Partition Manager software (trail version link ) Using which you redistribute the data into different drives or Add/delete drives.
Rate the solution as appropriate !
Feb 07, 2009 | HP Computers & Internet
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
1st you delete your unwanted driver....but u don't add this drive space ok....
plz tell me what u want ?
Nov 10, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
360 gb harddisk is not show the exact space .
*delete all the partition and redo the partition
Jun 25, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
101 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
