Question about Zanussi Washing Machines
User manual zanussi zwd 12270 wi - Zanussi Washing Machines
ginko
  • 19396 Answers
SOURCE: I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Posted on Oct 15, 2008
BIKER T
  • 909 Answers
SOURCE: My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
Posted on May 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: I am getting a Code E20 on Zanussi Washer Dryer
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
SOURCE: I have a zanussi washer dryer ZWD 14270w and the
Not sure how full the drum is when you are using the dryer, but I have this appliance and it works best if the drum is half full. If the drum is full, things don't dry properly because the air can't circulate.
If that doesn't work I'm out of ideas!
Posted on Feb 26, 2011
smitty5609
  • 243 Answers
SOURCE: My Zanussi zwd 1270s washer
Washers take alot of power to run. In the instlation manuel they say to have a dedicated electric line .
i had a problem with mine i had a sump pump and the dryer and washer on the same line and would trip my breakers.
You can run it off another line or extention cord as long as its rated for the needed amps.
Posted on Sep 24, 2011
I have a Zanussi Washer/Dryer Model ZWD 1270W. When I set the machine to wash (any cycle), it fills with water, the water jet starts, it takes the soap powder then it immediately skips to the 'drain'...
http://laundry.manualsonline.com/manuals/mfg/zanussi/zwd_1270_w_zwd_1270_s_zwd_1470_w.html
If you go to this website, they have manuals and you can ask questions also.
Just one thought. Have you unplugged the washer for a few seconds then plugged it back in? It's possible the "brain" needs to be reset.
Nov 02, 2013 | Zanussi Washing Machines
My Zanussi zwd 1270s washer dryer keeps tripping the MCB and i have no idea why, any help?
Sep 24, 2011 | Zanussi Washing Machines
I have a zanussi washer dryer ZWD 14270w and the dryer is taking hours and hours to dry anything..help!
Oct 24, 2010 | Zanussi WDA1055W Front Load Washer / Dryer
Zanussi zwd 1260w won't drain, no apparent blockages
REMOVE POCKET BY TIPPING MAHINE BACKWARDS. I HAVE SEEN ****** STICKS TO TOYS JAMMED IN POCKET.
Jul 26, 2010 | Zanussi ZWD1260W Front Load All-in-One...
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
