Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My heater turns on (h100) runs & heats about 20 seconds then turns off
A big problem with these heaters is the water pressure flowing through your system ..make sure you have sufficent pressure by cleaning all baskets and even inside your pump where the basket goes ...make sure you shut off the power ...this on off thing happened to me before and the solution was insufficent water pressure through the system ...once everything was cleaned out and pressure was up everything ran like new again
Posted on May 11, 2011
    Problem Solver:
  • 6 Answers
That could be a problem with the ignition sensor. If the sensor fails, the heater won't be able to sense that there is a flame. It thinks the gas is flowing freely without being ignited and cuts the flow of gas as a safety precaution. If you're comfortable tinkering, first CUT THE POWER AT THE BREAKER, then remove the cover and check and clear all the wire connections. Sometimes it's not a faulty sensor but rather just a loose / dirty connection. If that doesn't fix it, call a service tech to check/replace the sensor.
Posted on Jul 15, 2010
Comfort-Aire REG-183 18,500 BTU Window Air Conditioner & Heater cuts on and off when not set to auto on heat only
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Bulance AC Cleaning Repair Services
Apr 04, 2015 | Comfort-Aire Heating & Cooling
What is the difference between DM-H100 & 200?
One is a $20 mic and the other is a $30 mic. Both are "karaoke" mics. I can buy an AIWA DM-H100 Cardioid Microphone for $5 on eay and an Aiwa DM-H15 Cardioid Dynamic Microphone for $6.
Aug 31, 2014 | Aiwa DM-H200 Microphone
I have ran my 12-2 wire from breaker box to thermostat from the thermastat i ran a 12-2 wire to first heat. question 1) do i run another 12-2 wire from heat 1 to the next heater i want on this thermostat?...
There are so many questions. WHAT IS THE MODEL number of the unit that you are wiring The thermostat and the source voltage are two different things. What voltage are you wiring this to?
Apr 30, 2017 | Marley Electric Hydronic Baseboard Heater,...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
113 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
