Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My Hotpoint FWD60 dishwasher is working ok but does not heat up during the wash, there are no flashing lights, thank you Rita.
    President:
  • 1,430 Answers
This is likely the heating element has failed. This is easy to check and replace. Here is a link that should help http://appliancehelponline.com/dishwasherheater.html
Posted on Jul 13, 2010
Testimonial: "thank you for prompt answer will try link"
I have a slimline hotpoint SDW60 hotpoint dishwasher, when it starts up it goes on for so long then lights start to flash and it stops or hums loudly throughout cycle. There are 6 lights in a row and it is the4th and 5th lights that flash.. please can you help me!!
Posted on Aug 11, 2010
4 Suggested Answers
SOURCE: hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Posted on Mar 07, 2008
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: dishwasher error codes please help
ive got the hotpoint fdw60 with the fast and delicate light flashing can any one help please
Posted on Sep 25, 2010
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fwd60 dishwasher not working after a powercut.
If there is no power at all something has failed internally, it could be the control unit or the power inlet filter.
Mar 12, 2012 | Hotpoint Dishwashers
Hotpoint fwd60 eco and intensive lights flashing
Hi, I have a Hotpiont FWD60, the "delicate" lamp has started flashing about twice a second. Any ideas? Thanks, Nick
Mar 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
FDW60 Fault
Hold down the start key and you will re- set the D/W.
Please Rate This !!! Thank YOU !!!
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint bf162 built-in dishwasher error codes
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
FDW20P Error lights.
Hiya, i have the same problem. I am getting mine repaired on the 16th Next monday Booked an appointment with Hotpoint there coming to see and fix it. I will ask about the flashing lights and if you keep in contact i will let you know Ok"
Sep 20, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
1,431 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
